I think you'll take back that statement once it's been rebuilt...
MAYBE.
its just finding someone to build it and finding a job that doesnt require a car so that i can raise more money
how sad , my race weapon is my daily , ha!
im gonna kick myself for suggesting someone else actually do this,
but have you considered applying at the casino, mitch? weve got pretty high staff turnover at the moment, so were constantly hiring and training new staff, first few weeks sucks with no pay (training, not sue how thats changing with the eb's), but once youre through that, its close to $20 an hour, for as many hours a week as you want...
Edited by scandyflick
i have thought about it but i dont want to deal black jack or deal with people on a retail side of things etc as.
what sort of job's are there available because the only ones ive seen on the Sky City site is experience croupiers and HR Administration job's ;/
MAYBE.
no luck with fours n more?
most croupier jobs are no exp necessary. but theres main cage cashiers, security, gaming machines, valet parking, anything related to food and bev, just jump on the website and fire off some apps, its shit work, but if you need quick money, well...
cheers dave , will give it some consideration :thumbsup:
i dont like em. lol unless they are the cafe primo ones lol
lol Your not alone Cara, I cant stand pancakes either, gut bombs!!!! :)
give me waffles anyday..lol :O
and Damo my R34 front lip goes into production in a few weeks , all CF and fully functional venting..?
be up for some orders after a checking the arc on another front bar? cost TBD but hell of a lot cheaper then Nengun and better venting.
hope to have it done for the show and shine
Guest CleanAndSimple
know this is not that wanted section but nobody reads it anyway,
by any chance anyone got any 6" or 6.5" speaker covers, like just the plastic covers, my stock skyline ones have broken to pieces :) dont really want ugly holes there (Y).
will pay for them, just don't have to cash to do my sound system.
Hey,
Does anyone know how to get the faded stuff off the headlights when its on the inside? I use cut and polish to make them clear on the outside but one of them must have had mosture on the inside at some stage....
Cheeeeeers
Penny,do you have a photo of it?
it has a broken seal and needs to be removed and split apart to fix properly, dont attempt unless your confident in repairs, very fragile and expensive to replace if done wrong!!
to fix them to perfection use aircraft windscreen polish, or megulars m105 works pretty good to rid the haze followed by plastic polish.deeper scratches can be sanded out with 2000grit wet sanding followed by the above.
to dry them pop out a globe and use a heat gun or hair dryer on low heat, then put the globe back in.
hope that helps
Troy
I swear u guys dont know what you're missing. Some pancake recipes are shite (and dont even compare instant pancakes to the real shit).... you get a good recipe for home made french crepes, you wont be going to work that day...
waffles are cool too but i'd rate a good crepe/pancake over waffles anyday. sounds like u guys have been eating pikelets instead ;D
-D
pretty sure i have some, silver with a cross pattern no mesh . free to a good home
or i would suggest any car audio shop, they normally have boxes under the workbench overflowing with them?
-D
pancakes and pikelets, both foul..lol
my grandma makes some pancakes with 7/up or mtn dew in them. the bubbles make the pancakes thin and slightly crispy when they pop while cooking. much better then thick pasty doughy ones. some old fossil recipe but still not that crash hot on pancakes.
Edited by sapphiregraphics
man thats just lazy, shes using the soda in place of bicarb ;\ disgusting
a good pancake is rubbery and flexible... light but not aerated.... when u put salt and aeration into a pancake it becomes a pikelet (and i find them damn near inedible)...
imho the thinner the better - thick, aerated pikelets are like uncooked bread, which is a total degustation misnomer
-d
Guest
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
