oh yeah
im investigating instant power for my 4wd too
http://www.dieselgasaustralia.com.au
"This Diesel/Gas system will increase power and torque by up to 20% (sometimes more). This power increase is due not only to the increased combustion efficiency, but also the LPG itself produces power as it burns. So even the most economical gas map and driving technique will produce some additional power. A more powerful setting can still produce better economy than running on straight diesel."
"The power and torque increase applies over the whole rev range. Turbo lag is all but eliminated, and engine noise and vibration is dramatically reduced all the way through to maximum revs. The driver will notice fewer gear changes and higher average speeds, particularly on hills and when towing"
and for an equivalent for what i should expect
2002 Nissan Patrol GU Coil Cab
TD42T – 4.2l 6Cyl turbo diesel
5 Speed Manual
80,000km when fitted
Average fuel consumption 15l/100km
Standard Power: (red line)
96.6hp @ 3200rpm
840lbft @ 2600rpm
DieselGas Power (green line):
141.5hp @ 2750rpm (+46%)
1295lbft @ 2040rpm (+54%)
so, turbo people, looking at getting a new turbo for the s14, as the stocker is one its way out. not thinking anything massive, got it down to a garrett GT28R or GT28RS, just wondering if anyone here has any experience with them? ill probably end up browsing the forced induction forum soon, just seeing if theres anyone here whos used either first.
do it matty i wanted to put the skyline on gas but couldn't fit a donut tank in the boot LPG = higher octane than fuel
only problem with gas as i know is that it just doesnt have density and it requires some special injector to force the gas into each cylinder when its under boost.... my r31 had the simple setup, where as the gas is diffused into the air pipe before the plenum, but they aren't sufficient for turbos (and the fact that the lpg burns at a higher temp which could be an issue for some turbos)
-D
Well depends on what your really after Dave.
I have heard of people putting R34 stock turbo on and having a decent power increase by that.
GT2871R isnt a bad option either as i think thats what Dale is running in his 180 and is making quiet nice power.
So really what you want is to find out the maximum for your other parts ie. injectors, afm and etc
and then go with a turbo that wont be maxing those components out otherwise you might as well spend a lot of $$ and get everything done....ie injectors, afm, fmic, coil packs, ecu tuning etc
Hope this helps Dave
cheers krish, completely forgot about dale. shall have to have a chat with him. 34 turbo sounds interesting, thinking lag could be an issue with the missing 500cc though. just looking for nice streetable power, somewhere around the 150-160rwkw mark.
Then for that Dave i would say go with a RB turbo
from what i have heard it reduces lag on a RB20 so it shouldnt be laggy on a SR20 me thinks
good luck with whatever you do mate
I think one of my mates chucked a R34 turbo on his RB20 and made something like 180rwkw with fmic, fuel pump, pod and 14psi of boost
so wont suprise me Dave if you make a significant gain from that mate
lol they should fix the god damn roads
some of the roads around adelaide is absolute shocking
ohh and penny if you pay yearly rego you save something like $100-$150
IMHO thats a lot of money to be saved on rego
well at least thats another months worth of insurance for me really
Yeah I have decided that next time round I will do it for 12 months.
Its just crazy that we have to pay so much just to have a car on the road.
IMO push bikes should have to pay, they use the road too!! not to mention being a major traffic hazard at times.
I should be posting in the what really pisses you off thread huh.
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
