ca wouldn't even heat up a kettle :)
but srsly, CA in a keto would be fun, gotta look after the engine tho. 90% of CA's are old and thrashed, no wonder they dont last. If you think about the pre 91 silvias with CA's, that was 18-19 years ago, thats old in engine years.
all aboard the failboat.
http://www.skylinesaustralia.com/forums/To...93-t260430.html
holy shit! someone run this turbo
Garrett GT6041R
Information:
This large frame turbo is suitable for race applications.
Housings Available: 1.25 A/R, 1.47 A/R
Power: 2000hp
The price is still dropping :)
http://www.j-spec.com.au/list/index.php?ID=14119
yep not wrong on that one damo
if i remember correctly he made 185 on the boostworx dyno
not a bad power to weight ratio on that beast
That was 185 kw with a 10mm hole in the intercooler piping where a blanking plug came lose and fell out. That won't be happening again, now with added loc-tight.
What's with all the CA haters here, anyone would think it's a skyline forum. The only problem with CA's is that a lot of them have had a hard life and they haven't been well maintained, If you get one that's been treated with respect they make a good RELIABLE little power house. Have a look at the graph below, that's on a standard bottom end.
Here's the new graph from a couple weeks ago on a 36 degree day, and that's after i lost 10kw by going back to the factory manifold which we gained back by 1 more psi in boost, also gained 400 RPM in response with the factory manifold;
Edited by D_Stirls
such a nice and smooth curve and the power is coming nice and early as well
ahh now i know why you only made 185 on that day....would have liked to see this figure there
so am i reading it right Dale....your actually loosing 400rpm in response by using aftermarket manifolds?
I knew something wasn't right in the day because it was sssooooo rich, if you remember the exhaust manifold was also cracked at the turbo flange, when i took the turbo and manifold off it all made sense when i saw the 10mm plug had falled out of the compressor outlet.
Yep was getting full boost just over 4000 before but now it's more like 3700-3800 rpm, but at the cost of kw. Was making 216kw with the old manifold but with the factory manifold it was making 203kw, with some more tuning and the extra psi or so we got it back to around the same figure as the old manifold.
Earlier power = Torque so would have gained a few Nm in torque, but i don't have a graph with that on it.
Edited by D_Stirls
yeh damo ca in a keto would be a handfull!
CA's don't even need oil :)
Have had nothing but bad experiences with CA's (spun bearings, lack of women throwing themselves at the car when I drove past, etc).
But seriously, if you're going CA... just do yourself a favour and get a RB20!
Use the CA for a paper weight or something.
its ok i thought about rb20 in the keto lol..
but just abit too much work.. and would be way insane!!
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
