but why should everyone have to go down the same path, over and over and over again?
Cos it has been proven to be the best.
You dont see any Top Fueler drag cars running turbo's, cos supercharges or the best for those and turbo's are the best for RB's :D
My GF and i are heading off on friday arvo but won't be going to avalon till sat morning... gonna go to the NAB final friday night.
Got Gold class grandstand seats :D
Did you see the special on telly on sunday from last years??
Yeah im heading of 5am friday morning. might go to the night show. will deff be at the sat and sunday show. I go every two years.
Honestly my fav thing to watch. I would rather see a jet fly over and showoff than any car/bike/boat known to man kind.
the sound and speed is very impressive.
Yep. got the DVD from two years ago.
and thats all good and well........but im choosing to go with something different :P i aint changin my mind either :D and i couldnt give a shit what anyone on hear says or thinks about my decision.
My brother-in-law flew into Melbourne this morning and has a private 1 on 1 with the 2 Super Hornets tomorrow at Avalon, the lucky bugger!
because SHEEP tend to do that..lol :P dont follow the sheep ,, be U
CARA , your different :laughing-smiley-014: if you haven't noticed that yet..lol cause we have...don't worry its in a good way :D get a super charger,, good torque off the bottom end. god knows the 2.5 needs it
Edited by sapphiregraphics
I wanted to go soooo bad,, lucky bugger..
heard the show is a good one ???
maybe next time.
been buzzed the past few weeks with F18 coming down the beachfront at about 1500ft around 400mph,, he comes by once a week lately.trying to catch him on film but he is so low I need to be on the beach,, the house between me and the beachfront blocks him when i look off my 2nd fl patio.comes cranking down the coast,, takes him like 30sec to get from KI to me,, fast as hell a real challenge to get on film when you hear him you have to run for camera but he is gone already..lol
a few weeks ago he did a loop over the sea down low over aldinga, drools,, how fun
maybe next time.
I seriously can't wait... been hanging for years to go to Avalon. I only just got my r32 for track use and I've not even been out in it once yet to save the pennies to go this year.
However, will definately get the 32 out to the motokanas straight after that.
The guy who took me for my pilots licence flights used to do the fighter jet displays when the Grand Prix was still here in adelaide, I recall him saying something about glass houses and residing as a tutor shortly after.
They don't have to and i'm not saying that you should, but you can't expect CAPA to make a kit for skylines because the market would be tiny as there is a better cheaper alternative.
The flip side to not going down the same path as everyone else is that it will cost you big time because everything that you do has to be custom made and you are talking big $$$; hey i know as I'm running a CA which has pretty much no off the shelf support any more but then i have the advantage of having a CNC machine centre at my disposal.
i was hoping someone would bring up Top Fuelers.
The original reason they ran supercharges would have been off the line response as the turbos back in the day were laggier than there present day cousins, also there wasn't the electronic trickery that exists today (antilag and such) to help get them off the line.
The reason they aren't used now is because top fuelers are making close on 10,000HP these days and how laggy do you think a turbo that would support 10,000hp would be when a T51R only supports around 1000HP. That's like a turbo 10 times as big as a T51R (this isn't the whole truth though as Nitro-Methane produces oxygen as it burns so not all the oxygen for 10,000hp has to come from the induction).
Here's another interesting fact; the supercharger on a top fueler takes between 600HP and 800HP to drive (depending on gearing).
and here's some more i found;
Pretty interesting stuff here!
Some interesting Top Fuel dragster facts:
* One dragster's 500-inch Hemi makes more horsepower then the first 8
rows at Daytona
* Under full throttle, a dragster engine consumes 1 1/2 gallons of
nitro per second, the same rate of fuel consumption as a fully loaded
747 but with 4 times the energy volume.
* The supercharger takes more power to drive then a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the
supercharger on overdrive, the fuel mixture is compressed into nearly-
solid form before ignition. Cylinders run on the verge of hydraulic
lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output
of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the
flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above
the stacks at night is raw burning hydrogen, dissociated from
atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression-plus the glow of
exhaust valves at 1400 degrees F. The engine can only be shut down by
cutting of it's fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds
up in those cylinders and then explodes with a force that can blow
cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the
big end of the track) that sometimes cam lobes are ground offset from
front to rear to re-phase the valve timing somewhere closer to
synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an
average of over 4G's. But in reaching 200 mph well before 1/2 track,
launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for
once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this
sentence.
* Top Fuel Engines ONLY turn 540 revolutions from light to light!
* The redline is actually quite high at 9500rpm
* To give you an idea of this acceleration, the current TF dragster
elapsed time record is 4.477 seconds for the quarter mile. This means
that you could be coming across the starting line in your average
Lingenfelter powered "twin-turbo" Corvette at 200 mph (on a FLYING
START) and the dragster would BEAT you to the finish line FROM A DEAD
STOP in a quarter mile distance!
Edited by D_Stirls
cara just dont put the super charger on and then decide turbo after or ill kill you :D decide n live with it
sorry for those that have done it but i think its a bit lame buying a n/a car and putting a turbo on it when they have a turbo model, why modify it when you can go out and buy the same damn thing for prob cheaper & more often better. the only time i would accept a fake as being kinda cool is the shelby cobra kit car, because lets face it who the f can afford the real 1 and then have the balls to risk damaging it on the race track
^^ valid point and 1 i would reccomend aswell normally but i think cara more into being different than trying to shave seconds off lap times n bang for buck
Edited by Inline 6
Anyone going to the airshow will really love it. Best show in AUS by far.
When you have F15 Eagles, F16 Falcons. F18 Super hornets from the US. and other military jets from aus its really worth it.
Not really into the slower planes. I respect them. but they arent a spectical. slow and sound bad.
Pretty obsessed with jets actually. every yeah Ill head down and watch the jets at clipsal. Even if im not going in that year.
Avalon = $50 to get in each day. Think of the fuel costs tho.
Very lucky.
The trade shows would be good to see. Not as many people around.
Private one on one with a super hornet.
Not saying what I'd do to it. .. :D
being in the US Navy and working with Lockheed martin space program I have seen some interesting aircraft. etc
all I can say :D if you know what I mean..lol
nothing like a booster rocket test in the dark,, huge fireball glow and so loud its unreal
but isn't the beauty of being common is that there are alot of manufacturers who produce alot of different parts you can try? eg a turbo is a good example! there are so many out there you can choose from! just because we all have the same motor doesn't mean they're all set up the same
<drag engine stuff>
joisus... :D
"if it aint broke..."
you going roots type or centrifugal? im assuming the latter, youre still going to experience lag, granted, not the same amount as a turbocharged application, but its still there.
:EDIT:
spose i shall have my say in regards to the previous argument, re: discussions on the sa forum.
im going to direct the moderators to this; the WA wasteland.
im glad the moderators are more active in keeping the garbage out of the SA section, but one of the rather charming things about our humble little forum was the occasional random/non-car related thread, which we had a few of. so im thinking a dedicated wasteland sub forum like in WA would be good for us, sure its more work, but im sure someone would be more than happy to put their hand up to moderate the 'wasteland' sub forum, hell, id even raise my hand.
sure, we're all crazy car loving lunatics, but we do occasionally enjoy things that are non car related and want to share these thoughts with other SA members, but with the crackdown in the main section, none feel 'safe' to do this anymore.
(yes, my post is a little disjointed, i just finished work.)
Edited by scandyflick
and thats all good and well........but im choosing to go with something different :D i aint changin my mind either :D and i couldnt give a shit what anyone on hear says or thinks about my decision.
Good for you. Do it. Do it your way. Too many people are scared to fail and will never be adventurous.
When I built my supercharged SR20DE 200B, I had everyone in the "industry" telling me it could be done ... two fold: can't fit an SR20 in a 200B and can't supercharge it. I love proving people wrong. I drove that car around for 2 years before I sold it, as it was, registered and inspected with the SR20De superhcarged.
I got the same reaction when I built my CA18DET vg30BB powered 1600 wagon, 13B powered Bluebird, and T25 turboed CBR1000 drag bike. All 4 times, proven them wrong and been happy with doing it my way.
I came to the conclusion long ago that there are sheep out there with no idea ... they only want you to do things their way. f**k it ... do it your way.
:P
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
