just a word of caution it will be organised at richmond kartmania
and the boys dont like when people are crashing and bashing their karts...
if you are deliberatly seen doing that they will kick you off their karts
What about drifting them? :P Last time I was there I was chucking it into the corner just after the straight as quick as I could and sliding the whole thing as it tightened up :(
Giving the brakes a huge stab coming into the corner after the back straight is a bit of fun too :D
Edited by AndrewJZX100
Yeah I can imagine that'd be grounds for a talking to :P
It was only 2 karts on the track when I was doing so even if I lost all momentum (which is often in the slow Kart Mania rigs) then it wasn't a big deal :D I was just trying to get angles :(
Speaking of Go Karting, anyone been to Greenhills lately?
yeah ive been there older than that youngsta :( do they still have the big bouncy thing? it used to be a lil diff with a harder top making it better for getting crazy air
and yes dont bother with their go karts
Edited by Inline 6
spose its a good thing i was planning on pulling my engine out sometime soon. went down to the local bp to fill up, walking back to the 200 i noticed something dripping, so popped the hood, had a poke around, seem to be weeping coolant from around the turbo.
also had some old codger mumble to me (with my head in the engine bay) on his way past; "stupid hoons, hope your cars broken". :( stupid old codger doesnt even know me...
doesnt seem like much of a big deal though, just need to keep a couple litres of demineralised water in the car just in case.
And here's my "Holy Shit that's a pretty decent car that Uncle Daniel would love to have in his shed" links for the day:
A what?! http://www.prestigemotorsport.com.au/modul...hp?StockID=4727
pantera with a bodykit. would love a pantera, but the 'devil' seems a bit silly, really.
Love the Cosmo: http://www.prestigemotorsport.com.au/modul...hp?StockID=4719
much love for the cosmo. but daily fuel consumption to rival a C-17 globemaster on take off puts me off a little.
Did you reply with 'hey how'd you like to lose a bunch of teeth' Peter Griffin style? :P
yeah ive been there older than that youngsta :D do they still have the big bouncy thing? it used to be a lil diff with a harder top making it better for getting crazy air
Yeah still got the bouncy thing there!
pete get a new tow ornament did he? :D
:(:P
Did you hav ethe aircon on while you were going to the servo? If you did i think i know where the water was comming from.
oh, ive bought a set of pads for the s14 as i can hear the current ones squealing, nothing special, just something to keep my brakes going til i get my qfm's and rda's, but uh... ive never changed pads on 4 pot brakes before, so would anyone be willing be help out?
was going to buy a cosmo prior to the stagea
but couldnt even get behind the wheel - made for small people
tune tomorrow, just a quick little one. cant afford anything atm, bills to pay but no money
so, probably just an hour on the dyno mapping 2nd and 3rd gears, for air:fuel ratios and slight fuel/timing adjustments
got a set of 3-guages to go into a din slot, and the injector setup but no moolah to pay for install, yet
anyone interested in ecu eprom tunes?
eventually want to get a wideband sensor, rom tuner and muck around with mine, learn etc, then offer a service to remap r33's on a local dyno?
theyre pretty awesome... if you happen to own a petrol refinery. if you dont, well, youre screwed.
yeah, the fastest car I've been in was a Turbo rotary with 320rwkw. Awesome engines if you don't break apex seals!
i seriously think a decent 20B on idle would go toe-to-toe with a C17 on fuel consumption. ive driven a cosmo with a full exhaust, front mount, couple more pounds of boost, and i could see the fuel gauge dropping in peak traffic. its f**king crazy.
Edited by scandyflick
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
