im fking angry!
some wanker in a maroon 32 got full dori spec off brighton road into a side street (handbrake and all) the fk stain was doing about 80
i had to dive back on to the pavement, got a few cuts n grazes.
if you are on here, i saw your face, i know your car.....
Ohh wtf thats is just careless
glad that you got away with only cuts and grazes mate
More Kat Von D
much love for kat, you know she'd be an out there chick, and that shits just awesome, beats the hell out of a boring chick who refuses to try anything fun.
Most definitely.
"No boring bits!" :D
+1 shes hot... but too many tats for my liking too.
Had a chuckle not too long ago ...
Went on a night out with some mates, and was told I may not get in to some places due to my tattoos. I carried on about "you discriminating against the colour of my skin?" :) Ah, I guess it was one of those 'had to be there' moments :D
My point being, I blind man wouldn't find her tatts offensive. Its just skin and skin colour dude. :D
true ruby, very true
Id hit it.
lol
hey carl thats f**ked up dude,
yeah i know... im about to go for a bit of a cruise around the neighborhood, and see if i can find him for a chat.
injuries arent bad at all, just a bit shook up
its almost like she fell asleep while working a printing press for womans day and ended up getting sucked into the machine and printed with the gossip section, the agony aunt column and some pictures of angelina jolie...
-D
i might duck out back and cut up some aggh green ranger errrm and choof it down via mr.billeh
ahh hem
stag is with shaun today, on the dyno, told him couldnt afford anything more than a small tune atm tho.
really need to grow my own :) , .......
you never know Tangles, Shaun might look after you and do you a tune for cheap, seeing as you had heaps done there before!
ahh he does, he does :)
they are top lads down there
I cant see the bill being that much, $70 for shaft off/on, then basic dyno charge $80~
as I say to them, look after me and i go no where else, and am nothing but a patient understanding & (hopefully) good customer
query for the hardcore wastelanders
is there a market in SA for custom ecu eprom tunes?
something Im thinking of learning and doing...... learn on mine and then offer basic maps/install for others?
I would arrange dyno time, write a base map, check it out and write a remap... use 2-3 chips per customer, should only be a $300 all up customer cost?
a good emprom usb writer and a bunch of chips and adapters would be a grand start out costs
problem is the chips & adapters..... cost is around 15$ ea non-rewritable chips but adapters are 100 plus the soldering in .....
but yeah, sometime when Ive got 600hundrey to muck around with (tax?I paid extra the past 2yrs) I'll buy a eprom ecu burner and some of my chips, and muck around with it
"Chat" with him about a bit of road manners :)
Guest
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
