went to funkoars tonight. ive never seen so many full blown punch ups in a pit before.
nor have a i ever seen a vn do ringies in a bp forecourt before.
nor have i ever seen star force rock up en masse to a music event.
interesting night.
welcome to the dirty south lol, can garuntee more than half that croud woulda been good ol morphies blokes throwin punches
i am not happy with the way the car corners at the moment! turn in yeah it's ok the front feels solid but the rear twist under harsh cornering! i had a look at r34's to why they'feel solid and it turns out the reinforced the rear with some sort of brace behind the rear seats! basically there's too my flex more my liking!
isnt there a dedicated thread for that?
yes, but theres nothing saying i can't post it in here.
well just come back from down the street, there was a heap of people waiting on the side of the road
just waiting to see some bikies. there was a heap of police aswel, think there was 3-4 bus loads of police with
riot gear lol, i swear they had more police assistance than the Queen when she was here haha
sway bars help with body roll! but you can get a hint with the rear that it flexes while turning at higher speeds under acceleration
Replace every bush in your suspension with nolathane or alloy bushes, bracing the chassis wont do much if your still have rubber flexing in the suspension.
Have you got cradle bush spacers? If you haven't then what you are feeling is the rear cradle bushes deforming. Get some urethane pineapples and it will improve the feeling 100%.
Ok so having a weird strange problems with my car. Had baffle plate in coz of defect and have just recently put back in my stock ecu with remap including gtr injectors which are still in the car.
My car will run on low revs going thru the gears but as soon as i put my foot down to get it a squirt shoots massive black smoke out and doesn't move literally looses all power until i back of and slowly increase.
HELP PLEASE. I've changed plugs helped for a little
P.S i can still rev the s##t out of it while in nutral with nothing
Done the usual clean/check of the AFM? Could cause a similar problem, obviously the remap supports the bigger injectors yes?
Also, maybe an IC pipe has come off, loosened or one of the silicon joiners might have a crack in it. Check them all, you'd be surprised. Me and Steve both had a similar problem, that was the cause
Guest
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
