we'll as i told the person that gave me this i will put it up for them but i don't get or agree with tatoo's but hey each to there own
i got given this yesterday buy Ric's Auto Perfection's hairdresser
Might check 'em out. I need some more ink work. Wanna get some tribal done to mate in with my existing tatts from shoulder blade to arm and half chest ... then the other side done when I recover from that work :D
Just on that note: I had my last tatt done a fortnight or so ago when I was healed enough from my broken shoulder. They were like "are you sure?". I'd already delayed the appointment by 6 weeks, because I made the booking and had my crash the day before my tatt appointment. The shoulder bothered me none. :D
Edited by RubyRS4
this looks like a good toy to play with :D
The key elements of this design are a powerful 23CC engine, with a WT-630 carburettor and double wishbone suspension with adjustable arms. These complement each other for superior performance and almost unequalled turning power. Watch as it grips the dirt with amazing traction!
I know bro :)
I just dont know if I can be f**ked doing it ATM.... Need new injectors, Z32, RB25 gearbox and therefore new tailshaft, new/rebuilt clutch, want to change the fuel system as well (044 or 2 x 910's and a 2.5 ltr surge tank).... Think Ill just retune my current setup, make a solid 200 and be done with it.
And then spend more money on the corolla/ :D:D
and code for your signature
[url="http://www.skylinesaustralia.com/forums/Sale-t143697.html&view=findpost&p=3756525"][color="#FFA500"][size="4"][center]>>For Sale GTR (GTT & GTSt) Parts<<[/center][/size][/color][/url]
will look like
Me? nah, was too busy trying to get the R31 to even run. :worship:
I f**king hate the RB coilpack setup. Im going forward facing plenum and EA falcon coilpack, simply so I dont have to f**k around with it anymore.
AU you mean
AU you mean
Is it? I thought it was EL/EF/AU you could use too.....
EDIT - Nope, Just AU falcon I believe......
Meh. Whatever. All I know is I want either lead on plug or quick-release coilpacks :P and no valley cover/J Pipe.
f**king sick of having to remove everything to get at the plugs. Maybe Ill make a new pipe that curves back right after the throttle body and goes along the top of the inlet cam.
Maybe Ill chuck a rotor in it. Plugs are on the side then :D:D:D
Maybe Ill just burn the f**ker to the ground..... Im over it. :worship::):/
Edited by R31 drift pig
dibs on the good bits before you torch it
Everything has a price..... and if I was to strip it, 99% of everythig in it would be going into the new car :) ie. S13/cefiro...... or AE86 LOL
Nah, not going to torch it. Just a little frustrated and lacking enthusiasim atm. Got such a long way to go.
Maybe Ill chuck the Rb20 into the corolla :/:P:D
Nah, she'll be ok, just have to get off my ass and do some work. :worship:
Anyne interested in a Trust TD06 20G 8cm on a DMAX japan Stainless manifold?
Big f**k off turbo on a RB20 (250kw's on 1.1 - 1.2 bar) and super responsive on a RB25....
Are you serious or just messing around???
Guest
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
