nero is the problem, even tried burning through windows, still = fail
hahah >insert witty quote about redheads and burners<
sorry but how is nero the problem?
If the burn fails during the procedure, your burner might be faulty.
If you can't even get the file into a filesystem template and prepare the image, then give up and hire a nerd for half an hour. Then sell your PC and buy an abacus.
-D
Dammjust got back from my regency appointment and failed :D.
Got done for tiwsted brake line but it passed the brake test.
6 x 9 speakers in the back so they cut the metal parcel shelf and parkers and low beam on 1 side.
Does any1 know hwo or where i could get to fix/ put in a new metal parcel shelf???
please help
Parked our car in Jetty Road, Largs North on Saturday afternoon.
We had two (2) Port Power season tickets sitting on the dashboard.
Some bastard broke into the car and LEFT TWO MORE!
A rebuilt high flow i would of thought would be better than a 2871
52T 2871 will do 250rwkw and a 56T will do 270rwkw, i don't see a high flow doing that. Garret rate them at 460 and 475 hp at the engine respectively.
Edited by D_Stirls
Wow.... I guess they couldn't have been true port supporters
after all, you didn't mention that they'd stolen your car radio :D
-D
please help
cut metal parcel shelf........you'll be lucky not to get black listed for that (as the parcel shelf is usually part of the structural steel
might be worth checking out what nisswreck can do for you though
heres the question scott, how did you not know your headlight was out? i can pick it on any car i drive (especially at night).........and i woulda checked all my lights before going anywhere near regency anyway
Dammjust got back from my regency appointment and failed :D .
please help
are you kidding me for 6x9's ???? that means you could defect a lot of cars in this town. I dont care for 6x9's but that is petty shite , its going to be expensive to fix labour wise unless you can weld, rear window might have to come out just to keep from breaking it ,, that sux big time
try a body shop for install if you dont want to attempt it
anyone have about 20-30cm or so of 3M automotive double sided tape laying around? The tough stuff they use to stick on car trims, etc. NEED some.
superchump doesnt sell the good stuff, not the one down south anyway
you need the red 3M tape , used for trim, call up any auto paint store for it, or rare spares on south rd
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
