Dammjust got back from my regency appointment and failed :D .
Got done for tiwsted brake line but it passed the brake test.
6 x 9 speakers in the back so they cut the metal parcel shelf and parkers and low beam on 1 side.
Does any1 know hwo or where i could get to fix/ put in a new metal parcel shelf???
please help
Can be classed as structural support, so hacking away at that, in their eyes, is a big no no. In some cases, this means the rear parcel shelf needs to be engineered before you can pass Regency. That's happening alot these days.
friend called me today, his sisters boyfriends pimped as dr30 was stollen last night/early morning :P
was such a old schooler look too :)
ill see if i can get more details, was stollen around the woodcroft area though
Why you selling stockies?
Did you get that roll and flare done? How the rims going?
Coz i dont need them, they arent legal for regency so theres no real point in them laying around, a mate of mine wants to buy them too.
Havent got roll and flare yet. Rims going good!!!
You got your XD9 set yet?
What XD9's?... :P
Yeah I got them here. Using them as a kiddy pool for the dog. :)
... its currently there getting a cracked heater core hose repaired... fun stuff
Well got the beast back and while it took the guys a while to get to the rooted hoses, it was worth it. Not only was one ruptured and spewing my precious nissan coolant all over the front diff, but there were two others very close to giving way.... probably I could give advice to anyone with a 20yr old GTR that hasn't yet replaced the hose, now is the time ;P
And now I can drive without my car stankin' like anti freeze and peeing chloroform
woot
-D
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
