who can point me in the right direction, did a couple of searches to no avail. After info on LS1 coilpack setup on RB's, anyone know of a site or SAU link?
LS1 coilpack on a nissan?
Are you crazy dames? Best coilpacks arent the justjap or splitfires - its the good old nissan OEM coils
If you're smoking crack, I want some of that ;D
-D
OEM anything coilpacks will always out perform a just jap/super spark/splitfire coil. the commodore coilpack is rather common, why? because its cheap and it works, really well.
damo, head down to somewhere like morpowa and have a chat with them, if they cant help you out ill see what i can dig up for you. ;)
did someone say crack?
"i would never do crack I would never do crack I would never do a drug named after a part of my own ASS!
"Somebody says you want some crack I say "I was born with one pal! If I need another one I'll let you know but for now I'm sticking with the solo crack-ola thank you!""
It's late and I have had too much soda
-D
true that! the other branded ones are just cheaper replacements that work well but they're still not an upgrade
consider this, heat kills coilpacks. any coil setup as a 'coil on plug' arrangement are sitting right in the middle of the engine, yes? how much heat do you think theyre exposed to? ever touch your cam cover after a spirited drive?
the beauty of the GM/ford coilpack conversion is that they can be remote mounted, away from the engine, and shielded from heat. the lines from the coil pack to the spark plug itself can also be heavily shielded from heat.
the next and most obvious advantage is cost, call up your local holden spare parts department and ask for the price for 3 vn coilpacks (3 is all you need for a 6 cylinder engine) and then call up your local repco/supershit/sprint auto store about a set of leads, youll be pleasantly surprised.
(note: ls1 coil pack conversions require 1 coilpack per cylinder as normal)
if anyone has ever looked at a 2j coil pack cover does anyone realise how it's vented? now why didn't nissan think of that? that's why i don't have a cover :(
toyota packs still fail. they just cost 4x as much to replace. :(
how dare you take that tone with the name of nissan :no:
take it back ;)
nah, i think ill leave it as is. :(
:EDIT: this is how both toyota AND nissan should have set it up;
Edited by scandyflick
GUFFAW
I disagree sir.
A coilpack gets killed due to oxidization and increased resistance from contacts - not to mention structural damage if you are rough removing or fitting the coilpack itself
the coilpacks are exposed to efficient combusion via the heat conduction of the sparkplug itself as well as the ambient temp of the engine bay and cam covers etc... resistance increases with a temperature increase but thats only a factor of http://www.physicsforums.com/latex_images/75/759468-0.png
Which isnt really significant.
Temp does not kill coilpacks. They are designed to cope with engine bay heat. Its movement/shock as well as surface oxidisation from age that kills coilpacks.
is that the 7m?
uh... no.
1JZ.
GUFFAW
I disagree sir.
ah dohmar, you never cease to disappoint, something useful instead of the 'ah nu, not gm bru' argument that i was expecting from some. thanks. :(
news.com.au has to f**king go. this is my response to the topic http://www.news.com.au/adelaidenow/story/0...5006301,00.html
The article itself is benign however the poll has two loaded questions. loaded meaning any media turd can twist the results to his or her own devices.
This is what I wrote to them. I doubt they will have the balls to publish it, let alone act on it.
Wow AdelaideNow... again you've managed to put out a really unscientific poll. Fair enough if you were going to count a simple yes or no vote, but the addendum to each option totally invalidates the poll for what it pretends to be.
How on earth is crushing a car going to lead to violence? How on earth is crushing a car going to be a deterrent? And how DARE you associate traffic offences with violence! It is totally disingenuous. Its bad enough you feel the need to draw false lines from car enthusiasts and those involved in motorsport to immature young men and women who are blatantly disobeying the law, now you have to stoop to such a level to get your hits and sell your rag?? Your readers are not as stupid as you treat us! its just a shame there is no competitor for us South Australians to turn to for local news. You hold the monopoly for dumbed down journalism, and our society suffers as a result of your laziness.
I hope for the sake of the people of South Australia, that you all find a conscience soon. We deserve better.
Lets see if they grow a pair of balls, or a conscience for that matter.
f**king scumbags.
-D
Guest
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
