Yeah I've got that long arse threaded nut thing that I'm guessing is to add/release tension on the pulley but when I undo it it starts to come out of its thing and the pulley just stays where it is (as opposed to moving closer to the engine so I can get the belt off)
You also need to loosen the pulley nut itself, as that locks it into place. :(
^ yeah I missed that little bastard nut hiding under there :(
Would've been a lot easier if it was in a 32 or something, I can't actually fit my fking hand between the pulleys and the radiator, had to maneuver around them ;)
Got it on though :P
Edited by AndrewJZX100
Working my ass off today ...
Thanks to Damo (tryandcatchme) for loan of the ladder and lending a hand to get the purlins into place ... 5 more to go, but can't be arsed doing any more today.
Now you can see the shear size of the house extension. 102m2 ;)
Reckon jumping off the roof into the pool would be immature? :P
My back yard is an absolute mess now ...
Roof sheets go on this week right after I fit the remaining purlins.
Then I fit some tension bracing, before starting to fit the floor beams and floor joists.
Time for beer ... :(
be my guest, I want video footage though :(
I've hit the ground hard from dirt bike stacks ... this'll be an easy walk in the park having water to land on.
Better not let Tracy catch me tho ;)
Edited by RubyRS4
there's a skyline drive near the old spot hotel up north, much closer :( street sign has been stolen so much i think they welded it to the pole now.
So your telling us Dan that we now gotta take the whole pole instead of just the street sign...
got teh rolla started today with the new carby, and fix0rd fuel tank.... think i pinched one of the fuel feeds out of the fuel tank tho, not much fuel is coming thru.
bah, didnt want to have to take the tank out again
I've hit the ground hard from moto-cross stacks ... this'll be an easy walk in the park.
Better not let Tracy catch me tho :(
I'll put my hand up to film it then.... we'll even get the paramedics there on standby shall we.... ;)
I'll put my hand up to film it then.... we'll even get the paramedics there on standby shall we.... :(
"The following stunt is about to be performed by a professional 'jackass'.
Please do not attempt to recreate the following stunt ... or you'll be a dumb f**k too!" :P
Perhaps you might even find the video later on You Tube under "idiot misses pool" ;)
w00t w00t
sounds the goods chad, nice and clean
how much do you reckon he'd charge for some paint touchups / getting rid of a bit of rust out of one door?
Not to sure mate. I can give you his number if you want, work shop is called C.W Crash. Only prob is he is all the way out at Salisbury :blink: long way for us dirty southerners. Another good place down south is Daniel Stone Painting at Hackam, he did my 34 rims.
Not sure whats its gonna cost me, maybe nothing if my sister tells him to :D
Edited by DSTROY
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
