/random thought
im a loser
all i do is sit on my computer expecting a job to come to me.
wish i knew WTF i wanted to do , sighhh
Just a few things you can do:
-Go to an job agency and tell them your circumstances
-Call up Centrelink to see what kind of allowances and programs you can sign up to there
-Use Seek and CareerOne to keep a look-out for jobs, even in things like Customer Serice and Sales.
-Learn how to draft up a cover letter and resume, or get the agency to help you with that
-Do some work experience with a small business if you want to work in an office environment, or sign up for a trade/appenticeship
-Ask your family, friends and family friends to see if they have any odd jobs or work experience they can offer you.
Good luck!
Here's some wierd shit that happened tonight.
I was cruising to town with a mate to grab a bite to eat. We go through the stupid round-about thing in North Adelaide.... this guy on a motorcycle with P plates, and no helmet tries to squeeze in between my mate's 350z and another car... he gets through, then he cuts me off (if i didn't brake he'd be on my windscreen)... my missus and I thought fark this guys either pissed or trying to get away from someone... then about 15 seconds later i see him wedged underneath a late model falcon.
We all pull up, to see if everyone's alright... the dude on the bike had hit the falcon in the left hand door side, and his shoe is still wedged under the rear wheel. The bike guy is bleeding down the neck... goes to pick up his bike still dazed, and then as the driver he hit helps him onto his feet he jumps back on his bike and hastily rides away with us all trying to stop him.
Like I said some wierd shit LOL.
so would these wheel fitment stick out the guards on r34 gtt 4 door?
18x8.5 +33off fronts
18x9.5 +38off rear
just buy some r34 gtr rims and paint them
or head down to Bobjane T-Marts he's got some FULLY SICK chrome specials happening at the moment in his latest catalogue
ahahahah
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
