Just went for a cruise to the shops.
Looked at weather on the net first. No rain.
as soon as i fin washing the car it comes down. always does. always.
Also. A high number of ambos with lights on tonight. Seems the usual tailgaters cant do it in the wet,
Because of you Chad (yes, I'm blaming you :D ), I am now $10,000 poorer.
I pick it up tomorrow night. So it looks like I'm back into another Skyline :bunny:
Cant wait!
Nice one Kye :) Looks like a winner for sure :bunny:
-D
That 33 front on a 32 is disgusting!
Agreed.
And while rain always does come at the worst time, it actually worked in my favour and washed off a big ass bird shit on my roof... 5 seconds of flannel work and shes GONE
-D
wootage
Acquired a set of GTR sway bars tonight :D
RB25 BOV will be on it's way early next week :bunny:
Mate has a bleed valve I can have for free :bunny:
Recently got around to fitting black mesh to the openings in the front bar and grille so it looks neater :)
"the list" of shit to do to the car is slowly being ticked off, and so far a lot of the shit has cost me less than what I was expecting :D
Edited by AndrewJZX100
some days i wish i never stepped in a kitchen
this morning one of my f***n fryers decided to catch alight so we had to close the whole kitchen down and call the CFS, then tonight, i went and burnt myself aswell as being extrmeley paranoid about the other fryer and the ovens catching alight, arrghhh! not fun!!
lol nah nothing like that at all steve - i wasnt even near the fryers,not even using them, was chopping something tunred around and the thing was on fire!!!!
Wwas very scary thats for sure.........took a good couple of hourse before my heart rate went back to normal and i stoppped shaking.......
first instinct was i grabbed the fire blanket that was right next to me and chucked it over, aswell as turning off the fryers, and the stove tops, ovens etc
ive never had it before and i dont want it to happen again, im just glad i wasnt in the middle of service when it happened.
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
