went and saw fast and the furious last night was good except for the 180sx out the front(dragon) what a piece of crap, dodgy paint job, subs that max'd early then he just kept turning them up sounded crap and he left the engine running for like 2 hours just sitting there.
little lol for this morning
Posted by SoulChimera
Thats what first came into my mind so I stuck a few other games on and they seem fine. Outrun is screwing up without fail, every single time.
It's just done it again half way through a race, here is a picture of what I mean. It's not the best quality but you get the idea.
http://img.photobucket.com/albums/v94/SoulChimera/Outrun.jpg
I hope my 360 isn't on the way out again.
Posted by CVG Gav
I had a similar issue a while back when playing Silent Hill. Does the dashboard look the same when you quite the game or does it clear up?
My Xbox died eventually. No video signal coming out of HDMI at all.
Does it still do it with a component cable?
Yep, dashboard stays screwed up too.
Great, another 360. This will be my 3rd one. Luckily I didn't have to pay for the last one because it was the 3 red rings but I'm guessing I'm not covered for this problem seeing as it's the GPU and it's over a year old?
It's the old premium console so it doesn't have a HDMI port.
all i can say is GG microsoft
i got no idea how microsoft have avoided a massive PR issue, at one point there was like a 80% failure rate on the damn things lol
I think I remember hearing something similar once ^
I've had one red ring too. Luckily it was covered by warranty.
i need to find info about cooking, anyone know of any like sites, or can i search somewhere? thanks in advance
http://www.cuisine.com.au/
i got a bunch of recipes depending on what ur after, lemme know
-D
anyone know where i can possibly buy a car tonight?
something like a keto or some shit
my mums car is f**ked and i aint got nothing to drive
keto is not part of the some shit group!!!
Na, he's right they are shit. There only good for wanna be drifters with no money for a real car :blink:
fark, in need of 90 degree screwdriver. supercheap surely would have them, might pop down in a min..
cant you just use a stubbie one, those 90 degree ones are a pain in the ass to use.
Also, someone please buy my ute, or ask around for me. I've found a new car and need the ute gone.
Edited by DSTROY
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
