^Just polish up the ones you have :) use any paint cut and polish, and get at it with some force!
(presuming its yellow and thats why you want it replaced)
Nope, superglued (leaked on) and scratched. so needs replacing.
Edited by Damo_R34
It still stands LOL...
Check the turbo, check I/C pipes, Vac lines, AFM etc... general process of elimination, if you cant see/find anything, maybe take it to a mechanic....
cool!
i had a look and i'm now certain the noise is comming from the turbo!
Has anyone bought body kit parts from just jap? Im thinking of buying the r31 frount bar but not sure what the fittment, quality and postage would be like
JJR Drift Front Bar Set - Nissan Skyline R31 Coupe
$695.00
Dont bother. Aweful fitment and shabby fibreglass.
Contact Cazz (GTS-145 on these forums) And ger her R31 house Version 5 front lip and import vents, and use a new nissan S3 bar.... lot better result.
Exactly what I have on my car (bar the new bar, mines munted as shit ATM) Quality is great and fitment is perfect.
I hope you have the rest of the kit and wheels to pull that front end off.....
S3 jap lights are the same as Aus S3 lights, only the S2 afterburners are different to the Aus S2 "bar heaters".... good luck if you can find a set. And you need a different garnish for them. If you can get the lot for under $500.... you're a lucky man. If you can find them at all. Get S3 lights and be done with it.
Eyelids you can get from URAS.... or make them yourself with F/Glass or just tape the headlights, But I think they ALL look like shit.
Stock lights, no kit, slammed on Longchamp XR4's, straight pipes.......... Old school jap tuff.
What I would have done... except I have a full kit, massive negative offset 18's, bolt on guard flares etc...
Edited by R31 drift pig
$695.00
talk to Notorious-187 on R31 club, he has one on his S3
refer to my post in a sec under the next quote tho.....
S3 Front bar - go to Grand Nissan at Reynella - cant remember the price but you can get them new
Vents - Cazz ($75ea plus postage BUT she does come to adelaide 3 times a year - or u could ask me nicely and i can get them in july when im over at shep)
Lip - Cazz again ($325ish i think they were, same deal)
Iv seen the jap lights pop up on ebay somtimes and go for $400-$500 but i was hoping to find them cheaper lol if not il just spray the sr3aus lights black with some sunvisor paint. I was going to hunt around for the jap frount lights but the eyelids are alot cheaper.
Do you? otherwise it's just gonna look like poop.
If you want old school jap, gat an autospoiler and vents, and drop to the deck.
Hey cheers for the info il send her a pm and see what the price on postage is and what time il be looking at. Iv got a sr3 stock frount bar but if the new ones are cheap i might lash out and get one :banana:
Im only going with the frount bar,vented bonnet,eyelids,small boot scoop and old school deep dish rims if i can find them. If the car looks out of place with no skirts or rear bar il get them
It will Im afraid.... that front end is actually part of the R31House Ver 5 Drift kit......
this is the old school front end you want...
Or this one is a personal fav of mine...
Guest
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
