Have you tried knocking the gain back on the big muff for thrash? Sometimes it's more effective to lower the fuzz boxes gain level and drive the amp harder for a more "clean" (I know... sounds like a contradiction!) aggressive controlable gain that still sounds as heavy as all f**k..... use lots of low/mid EQ if your playing lots of 5th's.
I cut the mids and gain the treble and bass generally and use the gain as overdrive on the bigmuff and run it into the jmp1 on its clean channel and then into the low gain input of the amp... the cleans are what im after mostly, while using the big muff as only overdrive due to its sound in general. i know of loads of people who do use amp overdrive but other people live here so I have to be considerate and play at realistic levels ;P
Here's a pic of my hand built mic amp....
Looks interesting, from a kit i take it?
I'll dig out a photo of my custom Telecaster I built too....
My telecaster has 2 single coil pickups and one dual mode humbucker, each one controlled by an independant toggle switch (humbucker has 3 way) so I can get 11 variations in tone. Also has fender brand floyd rose which Im going to replace with an EVH Trans Trem... Might need to think about getting the tuners replaced at some stage along with a general service... need the electrics looked at cause when all 3 pickups are turned off there is some residual noise... and the barrel plug is worn as they always do... along with getting the top strap lug refitted...
-D
Edited by Dohmar
I'm hearing more & more stories lately of sensible peeps in modified imports not getting defected.
Me thinks they're judging you on the spot and making a pre-determination in their heads as to whether they think you're a hoon or not.
If they think you are one, you may come away with a canary......they obviously liked you James.
The only parts that came as kits to be assembled were the power supply and switches (these are universal and can be used on almost any mic pre), everything else I sourced and built. It's a clone of a very very famous circuit (Neve 1272) and I re-produced it as closely as I could possible with parts sourced all over the world. All aluminium internal components were hand fabbed.
-D
Nice guitar, I love tele's. If you're after new machines (tuners) have a look on ebay for Sperzel locking types. Not sure whether you have a preferred guitar tech, but I only ever let Steve Salvi (Salvi guitars - George St Thebarton) or Brian West (Fretco) near any of my guitars
My 2 Levinson Blade strats have that sort of arrangement with coil split humbuckers in the bridge and onboard preamp/eq via 3 way toggle that switches 2 variations of active settings as well as passive. Both also have locking machines. Only my Tokai Talbo has standard machines and one day I might swap these also for locking types.
My custom built Tele has Sperzel locking machines, EMG active pickups, Fender USA - Bridge/Neck Plate/Control Plate and USA made Fender licensed Alder body and a vintage style 1 piece maple neck and finished with a vintage style 5 hole single ply pickguard.
Custom Tele
yeah dave got the PM mate
will let u know asap
i had an exhaust leak a while ago and yes it sounds like one of those road trains lol specially on boost
BTW love the internet at the airport.....
Edited by Krishy
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
