reminds me of the jjr ebay special screamer, big mistake!
260 for screamer
400- labour to fit by un-named workshop (now closed :P)
only had it on for 2 days as the thing sounded sooo bad! like a tractor tbh
Hrmm... how about these??
I wish! AFAIK Tomei don't make dump pipes for RB25DET, so it's OK for scandy. About the only Japanese dump for RB25DET I could find is the HKS and they're nearly $AUD600 (which will almost get me a AM dump/front and hi flow cat). Then you need a front pipe!!!! I got quoted $550 for the CES pipe
As I mentioned before, I can't find one single review (RB25DET) on the internet for the dump/front made literally up the road from me by Advance and sold by Sinergy Motorsport.
ever heard of the macro setting it looks like this
macro image will come out crystal clear depending on camera from 1cm away
flower400x2ga6.th.jpg<<click
that picture was taken with my Tz3 7mp from maybe 5cm away and in the bubble area that was digitally zoomed with paint shop pro 400x
Hey Guys / Gals,
Just wanted to say good on you all for the massive presense of import cars in Adelaide!!!!
Im here on a business trip from perth, and Adelaide takes the cake for import central!!!
In two days ive seen many R33 2 and 4 doors, R34 2 and 4 doors (one four door with SOOO MII as the plates) Evo's WRX's MR2's everything!
Keep up the imports!! Its always comforting to see the familiar sights of round taillights!
So..... I kind of went and put a deposit on a new daily tonight. Pretty over driving the Hilux around, wanted something a little more luxury. This is what a got, should have it in my hands next week.
:P
Guest
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
