So..... I kind of went and put a deposit on a new daily tonight. Pretty over driving the Hilux around, wanted something a little more luxury. This is what a got, should have it in my hands next week.
:P
Congrats on the purchase. She's a beauty.
I've given up trying to sell my black RS4. Been months, mine's 2K cheaper with half the kms on the clock ... but can't find a decent buyer not trying to scalp me. Now also considering parting the silver RS4. Just tired of the headache.
What plans you got for it? Apart from cruising with the best breed. :wub:
What plans you got for it? Apart from cruising with the best breed. :P
is yours the 1 that was at christies show with the kit on it?
Im gonna try and leave it pretty much how it is, only thing i wanna do is put a towbar on it and maybe a front lip, if i can find a good one. Its an awsome car in mint condition and thats the way i wanna keep it.
Ruby, bring that dump pipe of mine with ya Friday if your coming out, i have a car to put it on now. Also do you know if R33 or R34 front pipes fit stags?
They should fit. To my knowledge its from the cat back that is different.
I'll bring out the dump this friday then :P Take a peek at the new toy too.
I wont have the stag for this weekend, but hopefully have it for next weekend
Sweet ride there Chad, will look good with the 32 in tow
Not sure if i can tow the skyline with it, i'll have to do a bit of research on what sort of towbar will fit on it. Theres a Stag in the 4 sale section that tows a EVO so hopefully it should be able to tow the heavy ass skyline at some stage.
series 1= r33 rb25det, i think, and series 2 is rb25 neo?
yes R33 S1 complete exhaust fits on a S2 stagea without too much drama Roo bought my old exhaust and everlast fitted it easy enough
good one chat, sooo holding back from saying Oh another volvo driver :wub::)
nice cara should be a reliable ride there not we all have dailies who are we going to spot
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
