FFS, my RB20 does not like stock bovs and I've got no fking idea whats causing it :dry:
It struggles to get to .4 bar at full throttle. With the bov blocked it makes .8 no worries. Also of interest is that the bov doesn't open properly when it's plumbed in. Opens briefly at full throttle but still flutters like mad otherwise, like it's not even opening. My old 32 would NEVER flutter with the bov plumbed in, like it opened even backing off at 0 boost.
On the plus side it seems pretty controllable to slide, even on stock sus with a weak viscous diff :P
Edited by AndrewJZX100
anyone got a ute/van/wagon etc and wanna earn $20 ??
i need to take my un-assembled bottom end to turbo tune and i dont have a working car !!
reply here or pm me or call me 0419848600
willing to pay more if you have to travel !
could be a leak on your BOV by the sounds of things andrew....
try another stock BOV if you can get your hands on it mate..
Thats what I thought, so I did just that and it does the same thing :dry:
Stock RB20 one does it and stock RB25 s2 that I just bought does it as well. I'm thinking maybe a vac line somewhere might be a bit suspect.
i would say that if its making the right boost when the BOV is blocked off then just leave it blocked off....Flutter FTMFW
but now it sounds like the vac line from the BOV to the plennum is leaking or something strange is happening
let us know when you find out what the problem was mate
good luck
PS flutters man leave it fluttering lol
PM sent
Not real keen on the flutter hey :P
Well, not all the time. Sometimes it's good (like driving through Mt Barker around 3:30 on a school day :P ) but yeah mostly it's just annoying.
What are you doing near a school andrew....specially on a school day :dry::P
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
