Put this over the airbag sticker
I don't know whether to tisk dissaprovingly or piss my self laughing
Theres heaps more.. some rather lame.. such as the V8 one at the bottom
^^^ I may or may not have this sticker on my R34 just for shits and giggles :D
anyone done the thermo fans and removed the clutch fan? looking into it. as i think my clutch fan is dying.
any points in the right direction would be chilled.
Yep I did it. Fairly big job, as the non-oem EL style dual thermo fans I bought did not actually fit between the chassis rails, but I made it all fit with an angle grinder and some cable ties. It will not fall out in a hurry, let me guarantee you!
But yeah, once I got it all fitted up it is awesome. When they come on it is so noisy it sounds like the world is ending, but even on a hot day my Cooling Pro radiator stays around the 90 degree mark.
I would highly recommend you buying a Pivot fan controller to run them though - as running them full time is not recommended (and noisy).
TBH I don't know exactly how much benefit they really give over the stock clutch fan - I actually think it is not worth the upgrade unless your existing fan is dying (like you say), and you want to have a play with your car.
cheers to those who offered to help me build a pc.
steve quickly whipped something up, in my budget, and sounds pretty good for what i need it for!
:D
EOI: 2 y/o pos toshiba satellite laptop, N/A (pretty slow) only 1.6ltr (ghz) and only scored 1 pussy (1 gig ram)
f**k me.
What a weekend.
Friday night: met a whole bunch of hot emo's at that Syke place next to Electric light. That was some sort of win. Then went for skids in a 4age KE70 with cut springs, locked dif and a crazy fuel pump/surge tank/swirl pot setup.
Saturday night: Went to the CD launch of Trancefusion at Live on Light Square. F*cking smashed it until 5am... then hit Earth til 6am, then Club 58 til 7am. Got home at 8am. Such a dirty night.
So much amounts of win.
And why the f**k do MC's feel the need to talk/attempt to rap/sing over DJ's sets? I went to Mansions at 1am to see Black Wax play, but they had a top bloke MC just rapping over the whole set, screaming shit like "Black Wax is in the house!" Well... no f**king shit.
Guest
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
