Mathew, I don't know who you bank with but I'm with the CBA and if you have enough business with them you may just qualify for a wealth package which includes a Viridian - In Line of Credit style account at approx 5% for up to $50K
I'm with ANZ and the business is with ANZ at the moment, Im hoping to not need the overdraft much as I will not be running accounts with customers... no cash no car. Simple as that.
I'm yet to speak to the ANZ but I will speak with the manager tomorrow at lunch and see what he thinks are my best options as there will have to be a mock agreement written up before I can do too much I would think
Edited by Stagstock
Dont you hate when you lend a fellow SAU member 2 Parts (roughly $700 worth) to get through Regency late last year, and after countless Pm's they never reply, call, drop the parts back off. Starting to Piss me off. Now i have to search around for his number and see what happens. :D
Sounds like your pretty trusting luke... mind you I've been caught in the same situation.. sometimes your generosity bites you in the arse.
sux to hear man, hope u get them back asap
thats why i dont lend out any of my stock parts, unless im good friends with them
LMAO.. ^^^ I'm so glad im not the only one who has to do that. ' Oh look honey there's *insert accomplace here* ... what a suprise... we should go say hello' lol
Edited by Stagstock
Guest
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
