female siamese fighter fish are not as attractive as males, and can be kept together,
males are the aggressive ones, and much better to look at..
damo, chuck him on top of your dvd player/set top box/something similar, this will help keep
the water temp up, alternatively, grab a heat matt from a reptile store and sit him on that.
EDIT: alternatively, stop being a pussy, and get a real set up, African Cichlids ftw
OR better yet, dont be a cheap arse and go and spend $20 getting a 15 watt immersive aquarium heater
it aint rocket science ;P
-D
I have one at home! They DONT like the cold, their metabolism slows right down, they barely eat, sleep all the time. Need to keep the water at at least 22 degrees, which im finding hard at the moment. Also, dont just feed them the little flake feed from the pet store, they need those freeze dried small dead worms as well, after all, they are carnivores.
All good, i purchased high protein betta food, water conditioner and ager.
Our office is warm and he is pretty active at the moment
Haha i got one too....i should change my fish's name to Lee :whistling:
my fish is called Jackie.....after Jackie Chan obiviously.....he is a fighter
your spot on Damo about maintaining the temp of the water and cleaning it every 3-4 days lol
Do it! or buy a second one and call it Chan. I need a another one to call Lee!
sounds like someones got a potential expensive repair to do, what happened to it?
god i hope not lol
just the 4wd light has been coming on for some time now...attessa error code 21
its ment to be the TPS which i have reaplced with a couple 2nd hand ones but the light still stays on so yer just want it fixed
anyone here know what it could be??
cheers
god i hope not lol
cheers
if you've replaced the TPS probably gonna be a bad wire or a miscalibration. apparently it does happen
http://www.gtr.co.uk/forum/109608-how-do-i...ion-sensor.html
-D
so, been working on the 200. pulled the spoiler off.
and something appears to be missing here...
and this is why its missing, old vs new;
pulled the turbo off, took a bit of f**king around, in pretty good condition, no shaft play at all. seems the oil i thought was leaking out the front seal is just from the rocker cover (blowby?), so i think ill be investing in a catch can soon.
see the thing is dave your running a SR not an RB :whistling: hehe
you can keep your lump of cast iron. :D
Good to see you finally got her off Dave! You need a hand putting her all back together once I get the dump for ya?
yeah, its been uh... interesting. ha. yeah, could use a bit of help putting it all back together. i shall provide beer for afterwards.
(and let you drive it of course)
Well i know it starts so im happy. Just need to get it all back tomorrow night, take it for a drive around the block and see if the new semi's rub on the guards. Knowing my luck they will. Nissan probably wont have the belts in stock to.
Guest
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
