tends to cost about $90 a week, on a cheap day of course. depending on how i drive, ill get anywhere between 500 and 650 km. so it isnt that bad on the juice really, hows the aristo stack up?
ill throw the keys at ya for a spin after ajd. :)
Well i think thats better than the Aristo, I cost about $100 to fill her up, and prob get about 500-550 out of it, so close(ish) I just thought the ol 4.0ltr would suck it down a bit more, well thats what i got told!!
to be fair Ryan he did say he's on his L's so in all consideration do you want him in a 150rwkw import or would you rather he hang around the import drivers asking questions learning about how much things cost and so on then maybe when he's 19-20 and off his p's he'll be ready to make a wise decision about which import he wants
sure i was having a bit of fun with the radio crack because its a commodoore, doesn't mean he cant be an enthusiast
Ring John from Marvey Tech top bloke and looks after car clubs
oh Dale that commodoore would be good fun :P what about a JGTC kit for it widebody and all :)
dsc02388sc5.jpg<<< Marvey's work
dsc02385sh5.jpg<<< Marvey's work
genuine question, why are you on SAU? If you plan on spending money on a VS commodore, surely your not likely to get a skyline or jap import anytime soon.
guyz guyz come on im on my l's and my mum gave me her car for free i cant complain
she gave me the car with f**ked this, f**ked that so i gotta fix it abit and the sound system
needs to be changed due to the shit speakers
and no im not getting my sound system from u-pullit
i went there the other day so i could pickup some
tyres i could do doughys in
plus all the stuff there is shit
im thinking of like a kenwood head unit
and some splits ill maybe chuck a sub and an amp in later
and i know i said in a vs commo i meant for lol:)
plz help stop laughing at the noob they call me
if you are on your l's maybe should be learning to drive properly first before going and doing doughy's in it. dosent surprise me at all your saying it though because your how old???
oh thats right and its the school holidays. :) maybe if i put two and two together i might understand something here.
yeah, leave, now.
Guest
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
