Its viewable from the front and isnt angled. Its legal, and passed regency without any hassles. I'd know about it if it wasn't.
-D
i wouldnt be so confident, regency arent gonna call you on sumthing like that, its a cop and cop only related issue. from the 1 officer i have spoken to about it the front licence plate must be straight in line with the front of the car and above 300mm high. i just went with a slim line cc plate on a bracket in the place provided so there isnt an ounce of IC coverd up.
edit** this would be the perfect thing for old mate neil to clear up.....
anyways im gonna go check this ns v sau thread for some lulz
Edited by rhys5169
I'd say Daves probably close to the mark :(
Something like this would be pretty funny :P
http://www.tradingpost.com.au/Automotive/U...ckToResult=true
this would be good for some goon bashing
Nonsense. It is a regency issue since they are the definitive authority for the stamp of approval. Them being "engineers" and sapol being "police"
FYI I did some reading tonight.... you're right about the left hand plates being legal, but so is mine - because the plates can have a maximum of 20' angle from front on - which mine is so close to front on, its not funny. and it never stopped me from getting owned by a speed camera (i got the notice for speeding 58kph in a 50 zone and it wasnt accompanied by a notice regarding the plates).
And why wouldn't I be confident Rhys? The relocation kit came from japan when the car was imported by its previous owner (writeoff) and it passed regency upon its compliance. The car has been here for 4 years and never had a defect notice. Fact. And I have been 'randomly' pulled over and then let off after a bretho check, and again on another occasion when they were checking registrations.....I can't believe you think that it would be otherwise, when you haven't even seen the car in person.... unless you're just doing your usual stirring shit routine and are basing your opinion on a 300 pixel avatar.
-D
Died, was looking like a heated battle was looming between Ruby in the blue (mesh) corner for SAU, and everyone else in the red corner for NS :(
I admire his dedication to reply to every cheap shot individually, layed the grounds for a pretty good shit slinging match but it wasn't to be :P
Edited by AndrewJZX100
wooowwwwww relax princess, i was just offering you information i had heard..... no need to get heated. i was just after a definitive ruling on it as ive only ever heard from others and this officer about the front on issue.
faaarkin internetz iz seriusss business
there was some epic lulz to be had in that short battle though, if only they had let it go on longer :)
wheres this lulz thread on ns
hey Steve, with your twin straight pipes exhaust do still use a muffler????
i was thinking of going to a exhaust like yours and return my external gate to vent to atmosphere again (miss scarreng ppl)
Just personally, I reckon he faulted a bit with the discreet call.
Full body kit, shiny 18s and colourful meshing (which you've gotta admit stands out against the black) isn't what I'd call discreet or stealth, but anyway that point had already been argued :(
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
