lol, family guy:
Chris: Dad, what's the blow-hole for?
Peter: I'll tell you what it's not for, son. And when I do, you'll understand why I can never go back to Sea World.
http://www.familyguyquotes.com/characters/...n-quotes-3.html
give me ur sr20 when you upgrade scandy, could use it in my pulsar for some torque steer fun. if the shell dosnt rip in half first
Rip the back half of the car up, rear mount the SR20 for Pulsar rwd fun.
http://cgi.ebay.com.au/1993-Nissan-Skyline...93%3A1|294%3A50
This guy is kidding right?
It'd be hard to sell. You could get an R34 GTR V-spec for that kind of coin :P
Edited by RubyRS4
yes both, :P
for me? please? :)
What are ya gunna do? ... spank me! :P :P :D
I'll only have the Stagea for the show. Too much to do. Wouldn't have a second entrant in time ... not in a fortnight. ;)
yes spanking could be part of the deal if need be lol :):P
well considering i found out i was lied to about the rear wheel power figures with the 850hp blower, the other two options were to a) go to a 1200hp blower which would cost me $4500 on its on (then on top of that would need belts, etc) or b) go turbo
now as much as i dont want too :P
im seriously considering the T51R as my turbo of choice, it has also been recommended to me by Sam at Chris Milton Engines, ill be going with the 1000hp one, which also means going RB30 bottom end, (dont have a choice).
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :D kinda works out good i think lol
and ;) to you to dave :P
:) I would hope you are no longer using the workshop who promised you 850hp out of the supercharger. You were told by MANY professionals on here this simply wasn't possible but you trusted the people behind the work to come through. Clearly they were out to screw you, I wouldn't be going near them for this build
:P I would hope you are no longer using the workshop who promised you 850hp out of the supercharger. You were told by MANY professionals on here this simply wasn't possible but you trusted the people behind the work to come through. Clearly they were out to screw you, I wouldn't be going near them for this build
i was only getting the stuff from them Luke, they werent actually gonna touch the 34 at all. i wouldnt be recommending that business to anyone personally. but hey, at least i found out before i got the stuff, i just cant believe they lied :devil: i think its so rude.
Get yo' bits, T51R SPL, etc etc, get it to Willall, and let them work their magic.
Willal.
no.
sorry.
John Keen will be the only one to ever work magic on my car Damo. you should know that as well.
is the T51R known as anything else tho? cant find it on the Garrett website. so im guessing its been renamed?
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
