i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
You think? ;) You're prob 100% spot on there :D
Oh no, I upset them :dry: I'm devastated :P
Edited by RubyRS4
im sure theyll be mourning the loss of a valued forum member and contributor for seconds to come.
when theyre not throwing insults at your banned self.
Edited by scandyflick
Yeah, I'm almost certain they're having unlimited and unrestricted flaming sessions.
Time for the elite keyboard warriors to join in!
"Quick, he can't respond, let's say something nasty!" :dry:
The score is now: 7 forums I've been banned from; 2 of them permanent IP bans :D
Edited by RubyRS4
did you get ip'd on ns? ill actually lol if you did.
Dunno. I couldn't give a shit enough to try anyways :D
Guess NS members don't like it being pointed out how stupid they are. ;)
Well, I'm off for my lunch break ... I'm going for a cry at the tragic loss :P I'll try to compose myself and HTFU before I return. :dry:
Edited by RubyRS4
:D This is great, Might invite the NS guys over here for some fun, Think they'd have a ball over here!!
So the guy that is spearheading the SAU SA has been banned from 7 forums......Geeez you guys know how to pick em.... :dry:
Hey mate..
Editted by SLED
9:1 afaik.
just for comparison, my old toyota ran a cr of 10.5:1 and didnt have any problems on any premium fuel. cant see how the lower compression nissan engine would suffer problems.
Compression ratios and cylinder pressures are not synonymous.
You can have 2 identical engines with identical comp ratios, identical ignition timing, identical cylinder and valve seat wear, identical fuel RON and yet have totally different cylinder pressures.
Alter the valve overlap (valve timing) either by adj cam gears or lobe profiles and cylinder pressures start to alter considerably.
Drag racers dial compression in or out of their engines using this method as one of many.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
