anyone know where to get that uber cool coloured mesh from? ive tried profix and midas, but they say its only show car material; needs to be exclusively ordered from hyundai..?
Edited by steveP
Hey - why is there so much beef between SAU and NS anyway?
I heard it was because most of you think that NS gets bad rep with the cops, but it was SAU that tried to befriend cops and then got defected, right? Yet us ns.com peeps don't have that problem at all... so that must not be the problem.
so...what is the problem ?
I'm gonna step in here and try and nip things in the bud cause I can see this getting out of hand.
Be warned that not only will your posts get deleted immediately but you face a possible life time ban from SAU if everyone from ns.com comes on here for some retribution towards Ruby or other members.
Ruby, SteveP, 5LTBETR & Deluxe, consider this a friendly early warning.
EDIT: SteveP, the couple of times I've seen you out, you're as quiet as a mouse, but so heroic in here.
I dont think its so much of a beef, its like two brothers living in the same room, or SA and VIC.
I dont have an issue with NS, having previously been a member when i owned my S13, maybe someone with the hate inside their soul can shed some light?
I also wonder this. Everytime I visit the SA section here I always read atleast one or 2 stabs at NS, yet when I read NS (alot more then SAU) I rarely even see a mention of SAU. :dry:
hrmm oh well back to classic skylines.
Yeh i dont understand either Bill, it all happened between a few people in the All Japen Day thread over on the corner of NS.com, and then today it has happened again, but seems to be with the same SAU member.
I used to frequent here alot more before, but things have changed, and now see myself at NS more than here now, I used to be a "Yeh NS is so childish" sorta person, but wow how things can turn!!
Thanks Pete for the early warning!!
i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
... just sayin.
correct
Hello :D
Just wanted to say that I have not bagged RUBY at all... yet.
Just also would like to add that he asks for it with his behavior.
I would just like to say that I did
and will continue to do so
The score is now: 7 forums I've been banned from; 2 of them permanent IP bans :dry:
how many e-creds does that take your tally to now?
how many more before you win the giant panda bear?
Well the issue is resolved. Found some octane booster in my shed, put it in this morning and she runs fine now. f**king shit fuel. :dry:
Edit: I should add, it doesn't matter if the engine is forced or na, shit fuel is still shit fuel. Don't you think NA cars suffer detonation too?
I've got a new name for V Power: Vagina Power = its a c*nt of a fuel :D
Just looking through ebay and found this, VP commodore styles much!
*looks a rear wheel arches* .... *Runs to vomit*
:P:sick:
Guest
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
