jake needs better brakes..anyone have an idea on how much dba slotted rotors cost for an r31?, i'd usually ask on the 31 forums, but the tab for sau was open so i thought i'd put it to good use for once.
try here
http://www.skylinesaustralia.com/forums/Rd...ro-t251349.html
:P
I guess there are no haters on here at the moment!!
I definitely don't hate NS, but observe that the vast majority of posters 1). are under 18 years of age, and tend to show their lack of maturity in their comments and posts, and 2). the vast majority of users actually don't even own a car - yet are happy to shell out advice and opinions as though they are gospel.
SAU users used to tend to be exclusively older, as the price of the cheapest import Skyline was $30k+. However, these days I feel a large part of the deterioration of SAU is the fact that a turbo Skyline can be had for well under $10k, and this opens the forum up to a myriad of younger users, who tend to type before they think on occassion.
Another big factor is the clampdown by SAPOL on imports scaring people away from the scene, or more significantly forcing users to be much more private in their discussions of mods/cars/cruises, which makes it seem as if less goes on around here.
Just my observations.
i agree with your observations. :P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
