who said anything about being homosexual? I was saying that if you want someone to cuddle late at night in front of a good chick flick, then go for it! Scandy was simply pointing out that when you go shopping, some of those types tend to buy heavier items, so its important to double bag so your items dont fall out on to the floor.
geez.
If your craving for some man-love Dan, theres a whole listed of nominees in the Sunday Mail. Also check the "Male seeking male" section.
apoligies it seems i miss read your post thought the last word started with a "e" and had a "re" instead of the "s"
can you make a banner damo? join now :) my club needs a banner to :D
might actually dig up a pic later n get you to make me a proper 1, been riding on your damn qoute down there for too long
Edited by Inline 6
he's back get him :)
measly bookkeepers can afford multiple bikes n cars, wtf am i doing this accounting crap for
Because I also do drafting as well as being the manager :P I'm multi-skilled ... I even have my own successful business blinging cars with anodised blue mesh :P
After looking at many options I feel we have no choice but to change our name, im proposing "Power Over Obstruction Friends". Felt this is a tuff sounding acronym that cant be made to sound gay, it also represents the obstructions we have overcome to start our club.
Now who's with me my fellow P.O.O.F.'s
But each party needs an opposition. I propose my own party to keep POOFs in line. Bringer of Attitude Dept of Australia's Secret Service ... otherwise known as BADASS. We need BADASS to control the POOFs.
I think I'll get more members than you :D
if we did, you just scared them away
coulda been worse, coulda showed them a picture of me. then they'd warn their friends aswell
lol ruby the "Power Over Obstruction Friends" dont fear badass i hear they like the.......ok im not going there. im done im done
finding you a gf. hes doing a movie, Tom Cruise plays you, Mission Impossible 3: finding the token black guy a gf
hahah dont need to Damo since your mum's always free hehehe
nah its all good brew no need to find me a gf....
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
