mate its your daily that makes you look old....lol and dusty
didnt you see the memorial post, the dato's dead. passed away month ago. rusted and busted
n i call you chicks feisty felines atm :P
Edited by Inline 6
lol more random plans outa you, depends on what the engine is what you putting it in me thinks.
swapping a l28 in a l26 dato would be a sinch, but dropping that rb26 in my dato might take some custom work me thinks :P
engine mounts fuel injection alterations, blowing the welds on intake
Edited by Inline 6
who knows how to do a engine swap? how long would it take?
Just the engine complete with box. About a day depending on your tools and skills.
Including changing loom, ecu etc ... f**k that!
RB25DET Neo
When you said you wanted something powerful from me ... I didn't think you meant my Neo motor! :P
In that case, you'll need the loom and ecu as well won't you? As above: f**k that!
Engine swap itself will be easy ... with a hoist.
Edited by RubyRS4
see if john can do it for you Cara, workshops have the required tools and knowledge to do it all in one go for you
go T51R SPL with a small supercharger for that down low response :P
yeah i know damo but its still gonna cost abit in labour if i get him to do it for me, if i can get the engine in and everything i would like to just have to take it to him for tuning.
loom is pretty much the same at GTT and i got a power fc which is for GTT anyway :P so i think i should only have to get FMIC and boost gauge?
You might find there are a few add-on bits on the turbo version of the Neo
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
