Yeah my S15 only made 200rwkw, but had all the other mods to support whatever turbo I wanted to put on it. I decided that 200rwkw was more than dangerous enough (could slide in any gear), but always thought about putting a Disco Potato on it to make 250rwkwish. Sold it before I made that mistake. Too much power for the street in such a light car.
The beauty of the R34 is traction control (and the ability to turn it off if u want). You can happily make that much power AND get it all to the ground.
what would be the most power you could make out of a stock r34 gtt engine?
and what is roughly the most power you can get using stock turbo too??
i am learnings you see :) lol
190rwkw ?
with fuel pump and power fc id say
Turbo back exhaust, pod filter, intercooler, 12psi boost, fuel pump and remapped ECU(can get it done through turbo tune[my mate got his done there with the mods I mentioned and got a smidge under 200rwkw on their dyno])
Yep, what Vu said.
Note that bigger injectors and cams will not help the stock turbo necessarily make more power, as at over 200rwkw it is well out of its efficiency range. Also note that unless you are lucky, a stock turbo will not last massively long at 12psi. If I were were you I would skip the stocker, as a HKS 25/30 like mine can be had for around $1,500, and the Garrett version even cheaper (makes slightly less power though).
Also, yes you would need bigger cams and injectors (my injectors run at up to 96% making 230rwkw) to make 300rwkw unless you went for a stupidly big (read = laggy and unstreetable) turbo. Not sure how long your top end would last with 300rwkw, but seems to be a fair few people doing it around Aus.
Guest
