mainframe computer in head office will only let us see a few different things...i can go on carpoint.com.au ...but not carsales.com.au...
http://www.bypassthat.com/ :banana:
HAPPY BIRTHDAY DOHMAR
sex: http://www.skylinesaustralia.com/forums/R3...an-t270578.html
my missus wants to give beyonce a good going over
im not sure whether to be happy for you or worried.
ok so Nat Bass isn't the best out there, but would you kick this out of bed:
i wouldnt :banana:
Yep, what Vu said.
Note that bigger injectors and cams will not help the stock turbo necessarily make more power, as at over 200rwkw it is well out of its efficiency range. Also note that unless you are lucky, a stock turbo will not last massively long at 12psi. If I were were you I would skip the stocker, as a HKS 25/30 like mine can be had for around $1,500, and the Garrett version even cheaper (makes slightly less power though).
Also, yes you would need bigger cams and injectors (my injectors run at up to 96% making 230rwkw) to make 300rwkw unless you went for a stupidly big (read = laggy and unstreetable) turbo. Not sure how long your top end would last with 300rwkw, but seems to be a fair few people doing it around Aus.
i got 186kw when willal got there mainline dyno and i had 3" turbo back exhaust, fmic, power fc, fuel pump and boost was 13.8 psi so go figure! same as my mechanics r34 gtt he got 191kw!
with a few mods i am making 211rwkw on 12psi but ur right Son as my stock turbo is running out off puff towards the redline......but really happy down low which is very good streetable power.....but just dont know how long that the stock turbo will last....it has been running 12 psi for about 1 year now and still going strong so looking ok atm.....and my dyno figures are from Graham West Dyno's
i wouldnt :banana:
I would. I hate it when people have a wonky eye, esp on chicks. Makes me wanna slap em and say "WTF are u looking at?"
Oh and I think shes got less talent than a 3 kilogram bag of horse shit. At least the horse shit can fertilize the garden, all she does is rip of lyrics from other musicians and spends half of her songs talking because she can't sing for shit....
Yeah I'm mean, so what...
-D
How much power are you looking for Cara? 300?
just wanting to know what the max would be for stock engine before i would have to do internals, the 500rwkw will be a while before that happens, and cause my car isnt a daily anymore, i guess 250-300 would be a nice "starting point" even tho i would start off stock and go from there....i know it prob sounds weird but i would rather learn from having a stock engine and going from there really.
i mean is it worth getting this ebc thing? and what the hell is a bleed valve lol
lol Cara. EBC = Electronic Boost Controller, recommended for the power your aiming at making, forget a bleed valve for your goals. Greddy Profec B Spec II is popular and not that expensive.
If you plan to go big, do it in one go, dont buy and test turbo's etc, will be too costly. Research examples of det Neo's makign the sort of power your looking at. Why not buy a RB25/30 from R.I.P.S?
Taken from http://www.ripsltd.com/products.html:
"RB30 Stock internal long engines start at NZD$5250 with RB25 head. (suit up to 600hp and 7200 rpm)"
Happy B'day Dohmar :banana:
i find her voice extremely annoying at the moment,.
and yes happy birthday ben!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :laugh::laugh:
i wish i could damo, but the engine alone is gonna cost nearly $13,000 to do.............and im a long way off from getting that sort of money atm.
the thing is, i could get to 300rwkw and be happy with that. its hard to say until im there. just one of those things really i wont know until im there, dont get me wrong, id still love to get to 500rwkw, but at the moment its gonna be a while before that happens :D
Edited by MissR34
Guest
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
