i could do that eventually but atm i would rather get the stock gtt engine in and go from there too cause i can use the head off the N/A engine for the 25/30 combo
so are you putting a GTT engine in, and building the 25 N/A head with 30 bottom end?
I wanna do a 25/30 build too. Lets do it together Cara :P
Would like: RB30 bottom end, RB25 top end, cams, cam gears, top mount manifold, HKS 3071 ... as a starting point.
But which car to put it in :)
morris oxford...power to weight like strapping a jet to a skateboard
Cara,
You should have a look at the lewis engines website as it has got me thinking right now.
www.lewisengines.com.au
here you go Cara, from their website:
TRUST TDO6 used two hours after rebuild. made 340rwkw on rb25 @20psi. $800.00
RB30/25 'TORQUE MONSTER' engines $6,900.00
Dis wat u want??
looks the goods :P
I wanna do a 25/30 build too. Lets do it together Cara :)
But which car to put it in :P
sounds like a good idea ruby :D cant wait lol :P
might have to check that out a bit more damo, cheers
oh
btw
what do you think would be better?
apexi power fc boost control kit (for about $730) or greddy profec b spec II boost controller (for about $579)
let us discuss.
:P
Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
Thinking of building a little project myself ...
RB20 block
RB25 crank
RB26 rods
Forged pistons (1mm oversize)
Ported head
Adjustable cam gears
Custom cams
Top mount manifold
HKS 3071 turbo
... for starters!
Want car to put it in? :P
cara is like a little boy that listens to backstreet boys, while wanking off to a picture of britney.....doesnt know what she wants.
thats my take on it anyway.
now, my LAST attempt to get this footage from sat night up on you tube, if it doesnt work, im gonna give up!
Guest
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
