do an rb20/30 Rubes :)
Doing some shopping around.
Thinking an RB30/25 build for one car, and an RB22.5(25)/20 build for another particular car. And I'm not talking about the car(s) you think I am. Then get the plate RRB 225 = Race RB 2.25 lt
:P
that will go nicely in the volvo aye ruby :D:P
Cara if your after 300 at the moment then you will something like a GT3071 + cams +porting + lots of boost and you may just still fall under 300kw but it will be more responsive that the other option which is a GT3076 which will make 300 with cams and has the potential to make more.
As for the RB25/30 build, if you are after a big power engine then do yourself a favour an go for a 26 head straight away. 26's have all the good stuff straight away like solid lifters and cams to suit as well as not having the VTC gear which you can't run with big cams. Although the NEO's have the solid setup they have a problem with an exposed oil gallery once you go over 9.25mm of lift and therefore your potential power is limited. The other good thing about the 26 heads is the availability of aftermarket parts like a wide selection of cams, valves, springs etc etc.
you have pretty horrible taste in women craig...
Thinking of building a little project myself ...
<shopping list>
... for starters!
Want car to put it in? :P
R31 Excel GT, Series 2, rolling on 15x8 -5 SSR Mesh fronts and 15x9 -15 Longchamp rears with heavily flared guards. sitting on the deck of course.
problem with that is, with the irs setup they run being designed somewhere back in early 1850's, youd be putting the diff through the earths core everytime you got on the gas.
Edited by scandyflick
Guest
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
