Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
i didnt look on nengun. must do me thinks lol
Cara if your after 300 at the moment then you will something like a GT3071 + cams +porting + lots of boost and you may just still fall under 300kw but it will be more responsive that the other option which is a GT3076 which will make 300 with cams and has the potential to make more.
As for the RB25/30 build, if you are after a big power engine then do yourself a favour an go for a 26 head straight away. 26's have all the good stuff straight away like solid lifters and cams to suit as well as not having the VTC gear which you can't run with big cams. Although the NEO's have the solid setup they have a problem with an exposed oil gallery once you go over 9.25mm of lift and therefore your potential power is limited. The other good thing about the 26 heads is the availability of aftermarket parts like a wide selection of cams, valves, springs etc etc.
if i got 26 head it means im gonna have to muck around and get another ecu and whatnot when ive already got one now. was going to go custom cams anyway with the 500rwkw build, they cost the same as buying them off the shelf (around $1200)
great, another option for them to bump up prices
damn, i hope they dont shelve the mobil 98 octane... thats gonna poop on my parade (caltex dont sell any form of 98 here in SA but they do interstate - what gives? :(
-D
EXXON are going to become suppliers only have no fear Ben there will still be a mobil 98 just branded something else may even be caltex
dad said caltex make some of there own fuel but they wont have enough to supply 302 new stations with fuel
also there is a clause that they have to purchase fuel for the next 5 years
I wanna be different, so i am thinking of a Rb25/26 (RB27) conversion, i think someone in SAU:Perth did one. It had around 400rwkw, saw it in a old HPI mag, i don't wanna go to the same extent he did, but finding info is near impossible. Anyone like to help out later down the track when i blow my engine up and rebuild to a RB27?
ATM i am planning for around 250rwkw or above. I have nismo 740cc injectors on the way, have front/dump pipe & exhaust manifold, a Haltech e11v2, and still deciding on either a GT3071R or GT3076R. The guy i bought the front/dump pipe from had a GT3076R making 280rwkw on a RB25, was saying when it hit boost was just wheel spin.
Im running standard turbo at 12psi, making a little over 200rwkw with power fc, fmic, free flowing exhaust, bleed valve. standard fuel pump, coilpacks, injectors, cams + gears, etc. i've considered the turbo upgrade options, but have something else in mind at the moment. high flow turbo will see 250ish, maybe a bit less, but if your building a dyno queen, your gonna need something like Ryan has on his 33, i think its 3582R? or if its a dyno queen, read: not for road use, you will probably benefit from a high mount turbo setup.
i run a built engine and big turbo, so does that mean u im a "DYNO QUEEN"...???
so if u run a big turbo like a GT35/40 it makes u a"DYNO QUEEN"" also WTF?????????
u dont see me entering stupid dyno comps
the only reason my engine is FORGED is coz a certain "well known workshop" blew my motor up on their dyno after i spent big $$$ with them!!!!!!!!
I don't know why people say that a RB25 with a RB26 crank/rods will make a RB27 because it won't.
RB25/26/30's all have the same bore 86mm so the only difference between the engines is the stroke. So guess what, if you fit a RB26 cranks in a RB25 you end up with an RB26 because the bore and stroke is the same as an RB26.
or might hit up a 1jzgt-e for it..
mad custom work.. just want something special :(
Why don't you do what a bloke in the States did with TE27 and fit a 1UZ-fe, I'd say that you'd be the only person in Australia with a V8 keto. Having said that the CA would still make more power.
Guest
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
