Got bass?
Got the shagin wagon rockin now :D
Not much room left for said shaggin! :P
My Stagea is going in to Ministry of Bass on Friday for an install of subwoofer + sub box + amp, some splits, Kenwood amp to power them, all hooked up to my JVC dvd head unit. I'll be "entertained" all the way to Kadina :D
nice doof doof you have there!!!
whats the specs on it?
I just pulled the sub and amp out of the Hilux.
Cadence amp and 15 inch Kicker CVR sub hooked up to my JVC touch screen DVD player. The front stock splits are doing a great job atm, at least i thing there stock.
Edited by DSTROY
do i need to get my cam angle sensor properly adjusted by a professional before i can start my car ?
and also , if i took it somewhere would they prime the cylinders , bleed the coolant, do the gearbox oil and re gap my sparkies?
Im running standard turbo at 12psi, making a little over 200rwkw with power fc, fmic, free flowing exhaust, bleed valve. standard fuel pump, coilpacks, injectors, cams + gears, etc. i've considered the turbo upgrade options, but have something else in mind at the moment. high flow turbo will see 250ish, maybe a bit less, but if your building a dyno queen, your gonna need something like Ryan has on his 33, i think its 3582R? or if its a dyno queen, read: not for road use, you will probably benefit from a high mount turbo setup.
Damo, you have just demostrated a lack of knowledge of both myself and dan's car. Obviously you know nothing about our cars and what 300rwkw is like with our setup. My car is driven most days and has not seen a dyno in months apart from it's last tune. I think your small penis is blocking your memory mate, If you dont recall i have experience all kinds of turbo's with all types of setups, from stock power, to 200rwkw, to 260rwkw and now 300rwkw. It's ok...your just another Y-Generation punk you wants everything everyone else has right now when both dan and myself worked very hard to acomplish what we have today and when you can't get it or can't afford it, you bag them out to justify your lack of satisfaction in your own car. I would like to meet up with you sometime so you can say to both Dan and myself that our car's are only dyno queens and not suitable for the road. I would also like to take you for a drive through the hills and show you just how subtle or how aggressive you can be with 300+rwkw. It's obvious you haven't experienced it before. So before you go jumping at other people and bagging their pride and joy, just think that i've been in the game and had about 7-8 years behind the wheel of over 200+rwkw cars and done everything myself.
Thankyou.
gt35r 18psi 304rwkw
fantastic to drive. Can whisper around and it's fuel economical 500km to a tank or let hell break loose with the press of the go pedal. If someone wants to come for a drive to experience it rather than guess what it's like...your more than welcome.
nismo fuel pump
nismo injectors
PFC
Dmax exh manifold
My own hand made dump pipe
My own Modified internal gate
Very stealth low mount setup
No blue silicon, no added colours or preservatives.
Tuned by none other than willall
Edited by Ryanrb25
nismo fuel pump
nismo injectors
PFC
Dmax exh manifold
Ryan has the BEST example of how to set it up right with stock internals
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
