  nugzy31 said:
i said hi to Anthony this arvo for ya mr THE SLED :) He still remembers you and your gtr
haha, ole Anthony Chucky Norris is a good lad....I reckon Adelaide Engine was his very 1st job, when he was just a snotty nosed little kid.
Has he kissed and made up with his brother yet?
  Nightcrawler said:
yeah nice looking "R32" there .... and it's non-turbo ewwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
Lmao.... not only does it say r32 GTR when it is clearly a R34 gt they quote the engine size at 2.6l non turbo. I was TOTALLY fooled. Definately a GTR... this is on my must have list.
  MissR34 said:
7 psi i think i read was the max u could do on the stock internals.
but the learning experience in doing a DE+T would be good!
go thicker gasket to run more boost? it'll be safer as well
but i quite liked your first intial idea of going for the tomei 2.8 kit! it could've really been a real weapon with the right cams
I don't think so Pete. I made the mistake of calling his brother "Anthony" a few weeks ago and he didn't look impressed :(
He understood it was a genuine error and didn't think I was taking the piss.
  Rocky88 said:
^^ yes but unlike being a journalist or a cop, car driving itself isnt a job... unless youre a taxi driver or something
So firstly you say it isn't a job, then you say it is a job...
Spent the morning getting of a small hangover.
Spent the arvo pulling all my FMIC piping off and replacing all the clamps. Still waiting on the silicone reducers, but I'll keep using the old ones. Lex has bought my old fmic kit (including piping, clamps and reducers) and he's been patiently waiting for me to get the whole kit together.
Weekends are never long enough :)
  Ripp3r said:
LOVE THE BLUE MESH :)
  RubyRS4 said:
It was only a matter of time before the blue mesh made the trend :P
LOL, I can see where this is going......"headlines"......."BLUE MESH, it's more than flyscreen, it's a way of life!"
hahahahahaha nice work Pete!!!!!! we should get a sticker made up for Ruby so he can put it on the Stag :)
  Matty 31 said:
i wonder how hard it would be to fit one of these bad boys under the bonnet of the 31
Mack RM6-285 - 11.3L 285HP inline 6 with 285hp / 1150Nm torque
probably difficult, but more important - do you want to use 31 for towing lol?
Edited by Rocky88
Guest
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
