only reason i came up with the idea
we had 17mm of rain in 24hrs this time last weekend at pt augusta. turned all the clay based dirt roads into shit basically
had 20t of loaded mack dump hookin sideways at 10kph................thought this might be the key i was missing haha
Matt this is what you want and it will fit;
http://cgi.ebay.com.au/TOYOTA-LANDCRUISER-...93%3A1|294%3A50
That's a beautiful piece of machinery there Dale.....that's a good price too IMO.
I've got the updated version of that engine in my truck but with 2 snails hanging off it.
Crap!
Got the news this weekend that my uncle is in surgery at the RAH ICU and he's not expected to make it. That will be another uncle I'm losing to bowel cancer. He is a top bloke and has lived a good life. Hopefully he's got some fight left in him. Bowel cancer is no joke people. I get tested every two years. Its only $36 every two years to ensure you can keep enjoying modding cars for years to come.
Crap!
thats sad man..hope he has the strength in him to survive through it
Spent the arvo changing coilpacks to not only find out that its not coils causing missfire, but also to snap off one of the bolts that holds the coil in. wicked.
aargh, these bolts are so fragile... i snapped like 3 of them when i had the same issue...
so what have you tried so far to find source of misfiring?
well i took out a set of heavily-siliconed coils and replaced them with a spare set i got with the car, chucked come electrical tape around them first, but no dice, still missing under load. only other thing i can think of is a split in silicone joiners/piping thats only opening up under load? Gonna book it in to Pitlane to get the bolt out and replaced, and see if they can't diagnose it for me.
So you've replaced a dodgy set with another dodgy set? Buy some Splitfires, if the issue persists then you can rule out coilpacks.
As for the bolt, depending on where it snapped, use a set of pliers, wrap it around the thread of the bolt and work it out that way, done that before on my car, easy as piss.
^^^ or take the whole cradle out if theres no bolt left on top of it... thats what i had to do...
as for splitfires... that would be my last resort because they are for suckers :ninja:
Edited by Rocky88
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
