whilst playing with coilpacks etc, i noticed that r34's have 2 butterflies? 1 in the throttle body, obviously, but one that remains open, that sits (looking top down) just right of the TB. what controls that?
anyone know who sells a cheapish front/dump pipe combo ?
need one today for under $200 locally !!!
hey Mitch, ring around, wreckers dude. bound to find something
if you really get stuck, i have a stock dump you can take off my hands for next to nothing, and you'll just need to source a front pipe to match.
i wish :P cant afford an evo, i would <3 a evo5 stripped/caged
got around 15k for a weekend/track car (obviously change from that is prefferable but you get what you pay for) motorkahna/hillclimb/grip are my main goals, the odd skid day wouldnt be frowned upon
R33 is pretty decent bang for buck, you can pick up one with some fairly decent mods for around the 15k mark. you can shove wide tyres on the rear for traction, throw in some adjustable arms, front sway bar, front and rear strut braces, half cage if you want to.
id stab myself in the neck before buying a 33, as cheap as they are now..... still would stab neck.
been lookin at:
32
s13
s14
180
id prefer one already set up for track use (built cars before, cbf doing it right now) so if possible cage/rims/tyres/few mods. ive been lurkin carsales/ns.com & here, found a few possibilities.
edit** if i cant find a worthy candidate from the import world ive got a mate who will sell me a modded sr20det with x-member and gearbox mounts to suit a mk2 escort..... a very tempting option
Edited by rhys5169
Note to self:
Sell black Stagea
Buy black Porsche
Drive Porsche thru city looking for imports to challenge (Stagea in this case)
Proceed to speed past at 80kph passing cops in the city in a 50kph zone
Watch in rear mirror as cops ignore Porsche and suss out speed limit obeying Stagea
:P
FAIL
Edited by RubyRS4
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
