after a couple more hours swearing and grunting, a 6 pack, an angle grinder, 2 scissor jacks, and a borrowed welder. the rear cat flange lines up, and has been fitted. awesome.
yay dave
somehow my work location for today got passed on to everyone else that needed to know except me
i rocked up to st marys depot to only be asked by the contract supervisor why i wasnt at morphett vale. seems the people that needed to be told got told sans myself
many lols
so Dave would half your problems be due to you having a S13 turbo on your S14 and not actually Andrews dump pipe, to which someone told you to get a T25 turbo on your car :thumbsup::)
lol. i dont even know anymore. its done. nuff said. but the first dump and front were waaaaaaaay too long. ill be checking the numbers on the turbo again as soon as i can get my grubby mits on a scope.
The turbine housing on the T25g and the T28 are the same so the dump will fit both. When Andrew made up the exhaust what exhaust did you have on the car? I know that the fir instance the only difference between teh CA and SR dumps/ exhaust on S13's are the bolting pattern on the dump/exhaust so when you fit a SR exhaust on a CA you ahve to mod/rotate the cat flanges so they match up.
On a side note a mate is flying me to Melbourne on Wednesday to check this for him and drive it back if there's nothing wrong with it (he doesn't currently have a licence).
http://www.carsales.com.au/Tig/UI/PagePopu...;autoplay=false
Horsepower sells cars, torque wins races
i disagree i think donkey kong was the best game of all time
dont forget to argue ca18 in there to :thumbsup: lota ppl argue they the suprior engine
proceed
Edited by Inline 6
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
