The turbine housing on the T25g and the T28 are the same so the dump will fit both. When Andrew made up the exhaust what exhaust did you have on the car? I know that the fir instance the only difference between teh CA and SR dumps/ exhaust on S13's are the bolting pattern on the dump/exhaust so when you fit a SR exhaust on a CA you ahve to mod/rotate the cat flanges so they match up.
it was just an apex'i catback before i got the am performance gear and hiflow cat.
why would i want less power and a heavier engine?
srsly. sr20 > rb20.
RB20 are Shite load stronger Jeff and TT boys proved that, lets see a stock SR20 make 370rwkw without throwing a rod or splitting a bore liner
Also the difference between the JDM SR20 185kw and the RB20's 165kw would be the difference between the RB's 7psi and SR's 10psi they ran. Also remember that ADM SR20's made 147kw.
yeah, ill see what i can find.
still got the apexi, the cat is jjr.
haha, i remember the thread about that. fairly crazy shit.
Edited by scandyflick
no. im the guy with an s chassis apexi catback on an s14.
andrew however seemed to believe that most of my exhaust consisted of r34 parts.
meh. i dont care anymore. its fitted.
catback is for s14/15, cat is for s14 (hi flow is the one with the flange that wasnt quite right), original cat was original (lul), dump and front were original and the front pipe bracket (to the box) fit perfect. first am performance pipe didnt.
im not blaming his work or questioning his knowledge, because both are awesome. but at the end of the day, new pipe fits the way the factory one did, bracket and all, old one didnt.
Horsepower sells cars, torque wins races
i disagree i think donkey kong was the best game of all time
dont forget to argue ca18 in there to :ermm: lota ppl argue they the suprior engine
proceed
Well i've been in the process of proving that they aren't the piece if shite that everyone thinks they are, After all my car is making 247% of the power it came with from the factory for over 18 months now, and it only ever get driven hard.
Lets see a standard RB26 make 470rwkw for that long including track days.
^^ no offence, nice car, but if you drive around in this people will think you're either a spoilt kid with rich daddy or old fart with too much money.
... or someone with a big dick! :ermm:
sounds like statements jelous ppl that cant afford nice cars make :ermm:
u all do realize ppl say simmilar things about your cars to when they rolling in their pos cars
Memphis: I've been in L.A. for three months now. I have money, I have taste. But I'm not on anybody's "A" list, and Saturday night is the loneliest night for the week for me.
Roger the Car Salesman: Well, a Ferrari would certainly change that.
Memphis: Perhaps, Mmmm. But, you know, this is the one. Yes, yes yes... I saw three of these parked outside the local Starbucks this morning, which tells me only one thing. There's too many self-Indulgent wieners in this city with too much bloody money! Now, if I was driving a 1974 240z..
Roger the Car Salesman: You would not be a self-indulgent wiener, sir... You'd be a connoisseur.
Memphis: Precisely. Champagne would fall from the heavens. Doors would open. Velvet ropes would part.
slight adjustment by myself :)
there's cheaper aston martins like that around, im in the process of trying to con my rich friend into buying 1. theres that and a beamer and jag that kinda look simmilar that i constantly send him sale adds for :(
and if you want ppl to think you have a big dick ill give you 1 of the empty box's of condoms i finished that you can strategicly place and say o i forgot i left those there
Edited by Inline 6
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
