lol drunken weekends....friday night..drove to stansbury...played a game of "scumbag" (cool card game)....saturday...rode motorbikes....thrashed cars...blew a bluebird radiator to bits doing a burnout on my uncles burnout pad....fixed it and kept going....got drunk as a monkey sat night in front of the bonfire which was visible from the port river expressway....sunday...kinda hungover...watched my wife do helis in her v8 falcon out in the paddock...drove home...played guitar hero metallica.....monday...slept in....re concreted my missus's nannas letterbox in after some punk kid broke the pole it sits on....got a box of endone for my troubles...went home...whipper snippered the front yard...cut firewood..got fire going...took endone...sat watching telly...comfortably numb :happy:
my weekend rocked
saturday. sat and bored myself shitless with a heap of lessons for this army drivers course. came home, went for a mud bash sat nite
sunday: went to u pull it for a couple of bits, sold my roof rack to a mate in the arvo, then went for a big mud bash with luke and flick and a few of my mates
monday: went across town and worked on the skyline all day, then worked out i had homework from this drivers course, so went for a drive last night
today: RDO, finishing my homework off hehe
Damn ...
Stagea is stuck in 3rd gear. A/T light flashes at me and stag drives in 3rd gear (since lunchtime today). Had a service and shift kit installed by MV Auto 10,000kms ago ... whole car only 61,000kms old. Anyone got any ideas? I've already hit up the Stag section for an answer.
:happy:
Registered the silver Stag today, so I guess thats a sign to take the black stag off the road for a while. :ninja:
maybe the speed created by the downforce of the JDM MESH caused some to dislodge and wrap around you transmission dooflickey
i think it is related to the blue mesh....too much downforce, power, torque almost too much everything really with that BLUE MESH :happy:
i think since the blue mesh has given you too much power etc your transmission cannot handle it anymore.....time for more blue mesh and a better trans maybe.....
on another note check if your ecu hasnt gone into limp mode.....if using aftermarket ECU maybe check the data and see if there is something unusual in there....goodluck with it all ruby
No aftermarket ecu. Stock ecu does appear to be in limp mode. I've browsed the Stagea and Transmission threads and have a few options (although none are definite solutions). I'm going to start with the easiest solution and work my way up to the harder (expensive) solution, by checking the trans fluid level first. I doubt its the solenoids (and hope they're not) as the car is only 61,000kms old and MV serviced the box less than 10,000kms ago ... plus the shift solenoids are expensive!
If all else fails, I guess I'm doing that manual conversion sooner than I thought. I'll also check the Mv invoice for the warranty period and have them dianose the box problem. I'll drive the silver stag around in the meantime.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
