Should've read "stuck on 16psi" not "stuck with 16psi" ... not like you had a choice by the sounds of it.
Obviously you ran it on AWD. I'll be squeezing my lemon later in the year to see what I can get out of it ... in AWD also (and a manual box conversion).
I recall Ben (Grim) passing comment to run 24psi in this stag eventually. Be interesting what he gets out of that "family wagon".
Yeah, stuck on. No choice, still happy but
@Ryan, yes, yes you do :)
Guys, my car is still up for sale...It needs a good owner...It's sitting in the workshop all lonely. :)
$18990 Might wack it up on Carsales soon.
I NEED a GTR.
im so tempted by that. its almost retarded.
So whos gonna join me in the 400kw+ club next year? I cant be the only one.
Is this 400kw+ in drinking booze?
No one can compete with you there Luke :) You the champ.
Guest
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
