thats f**** disgusting.
423awkw makes up for the less than tasteful body styling.
im sure it was all the rage in the show circuit at the time, difference being, its a show car that has the balls the tear up the actual circuit.
in conclusion, i couldnt care less what it looks like, its awesome.
Edited by scandyflick
wheels fail
wing fail
kit fail
bonnet fail (purposeful sorta yet fail)
shoulda put heslo's car out there instead..........he pulls the chicks lol
Non airbag wheel fail
Turbo cooking engine covers fail
Lic plate in front of indicator fail
Defect waiting to happen.
Yeah, Luke's car doesn't scream "look at me, defect me"
Edited by RubyRS4
hurry up and post some pics then.
gonna get some tomorra, but just so i can say i told you so, needs MOAR offset. will change rims to sumthin nasty when cash allows.
i would have your ex 32 gtr over a chaser any day of the week!!!!! that thing was mint
whats your excuse!?
yeh that gtr was f**king clean, but mehhh, i needed a more practical car, didnt want cop attention, and it started to get a few km's on it and there was a good few thousand that needed to be spent to keep it sweet. i used that as a chance to move on, try sumthin diff :laugh:
Sold your GTR rhys?
yeh mate, bout a month ago. made a bit of cash on her with an offer i couldnt say no on, will definatly be buying another down the line, great cars!
would there be anything wrong with running a series 1 r33 turbo on a series 2 motor ?
lol Mitch it will be fine mate.....as my sig said making 211 from a stock s1 turbs brew
hey hey luke! your in a for a chance now :laugh: .............hopefully that means krishy will leave me alone :P
leave you alone....i mean come on how would that be possible lol
you love all the attention Cara......:P:P:P:P
yeh that gtr was f**king clean, but mehhh, i needed a more practical car, didnt want cop attention, and it started to get a few km's on it and there was a good few thousand that needed to be spent to keep it sweet. i used that as a chance to move on, try sumthin diff :P
a few thousand is a small price to pay on automotive perfection :laugh:
jz tis pretty cool though ill give ya that
Guest
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
