yeah well it is the first time it has happened in nearly the 3 years the exhaust has been on.......
The 33 goes to AAA tomorrow for a resonator to be put in between the cat and muffler. To quieten her down a tad :P
LOL! Are you going t'row?
I'll head into PQAD t'row to pick up a part from Ray.
Nah, doc gave me 3 days off, back to C.A.R.E on thursday. Gives me a chance to do a few things. Working 7am-5pm all last week, didn't get feck all done.
yeah hey, I am/was doing 7.30am-4pm today, tommorow and Thursday, its like a write off of 3 days lol. When I do afternoons which is 4pm-12am and even nights which is 12am-7.30am I can still do shit. Not to mention afternoon and night is a higher pay rate :P
With you on that Dion, love doing arvo's. Hate getting up on these cold mornings, and i know the worst is still to come. plus i dont think the neighbours like the sound of an RB with straight through exhaust at 5:30 am :P
i love having people who are awesome at fabricating stuff. Need a new seat in the patrol (as the frame is bent on the drivers seat) so my mate has said to me "get something thats comfy and we'll make it fit. Needless to say im purchasing a pair of HR31 Coupe seats and fitting them in :P
Edited by Matty 31
Yeah I hate cold mornings, because my work is on the road between Lyndoch and Tanunda, naturally it is cold as f**k like this morning was. Mind you I cheat in the house..... ducted r/c a/c + timer FTW lol. I'm sure you are very popular with the neighbours with your 33, it sounds awesome though, not shitty loud like some cars.
Edited by dark.sky
I did the same with my Hilux, 32 seats FTW! only took an a couple of hours to cut and shut. It was a bit of a pain in the ass though.
Guest
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
