another f**king week til i get my intercooler pipe.
im starting too get pretty pissed off not being able to drive it.
f**kin things gonna run out of rego before its moving. f**k.
I am home working on my R34 for the rest of the arvo/early evening if any of the Northie guys want to come up and have an ale/chat/help.
gotta go and stomp on a tenant in Walkerville 1st but may drop in up the road after
I'd be more than happy to drop over and distract you from being productive :wacko:
PM me ya addy (or I could just get it off the SAU:SA membership form) :blush:
as far as i know he works every sat morning damo........
+1
I'm very certain he will be Damo.
Shoot me a PM with your addy andrew and i might join ruby in keeping you from being productive :blush:
btw who is going to villis tonight?
I will be collecting deposits off people then :wacko:
someone snap these up, JAMES!!!
http://cgi.ebay.com.au/TOYOTA-COROLLA-MAZD...93%3A3|294%3A50
So anyone have experience of pulling out snapped bolts? Need a hand :blush:
Would be good, but stud pattern is too big, need 4x100pcd
Whats the drama with the stud Damo?
Well its one of the coilpack bolts, the very front one (closest to bonnet). The 34 doesn't have a removable cradle like the 32 and 33 do, which would make for an easy removal. Captain thread is like the only professional removal service, and hes $99 for my suburb.
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
