theres some dam good stuff in the how stuff works videos! i never knew how a tourqe converter worked before this one. he craps on a fair bit but still gets the point across.
http://www.youtube.com/watch?v=Kfksv9jFE4w...feature=related
Ever wanted to know how a diesel engine works?
http://www.youtube.com/watch?v=K9ZkDXadpJk...feature=related
Edited by Jack88
Hey everyone, Im looking at getting a 32 GTR in the next few months, just though id say gday and try to start to get to know some of the SA people. Im keen to come out to meets and stuff when I get a GTR.
cheers Sean
What compels one to advertise shit for sale on this forum then abandon it.....? Got me farked!!!!
that annoys me too.....if it continues to happen where a seller does not reply after repeated attempts over a few days, report their post to me and I'll bin it.
Get licenced up bro and come out on the road with me!
lol, a bike licence? my mum always said she wouldnt let me live under her roof if i got a motorbi...
... scratch that, she dont live here anymore. ill go and apply on wednesday.
umm this is gonna be probably sound dumb for u turbo peoples
but if i get a stock r33 turbo, will i have to get a stock r33 bov to go with it or can i get a r34 one if i cant find a stock r33 bov?
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
