umm this is gonna be probably sound dumb for u turbo peoples
but if i get a stock r33 turbo, will i have to get a stock r33 bov to go with it or can i get a r34 one if i cant find a stock r33 bov?
Lol cara the Blow off valve its self has nothing to do with the type of turbo you are running so Just use a R34 BOV or whatever you can get your hands on, Maybe get an aftermarket one that lets it go to the atmosphere so you dont have to worry about modding your air intake to suit the plumb back factory style.
block it and make it sound like you got 100 pigeons stuffed under your bonnet....btw cara may i ask why you getting a R33 turbo and not something bigger as my stock turbo makes 211 and then sort of runs out of puff towards the end...and no point turbo charging a NA, only to be limited by the turbo......get something bigger for around 300+rwkw mark.....well thats at least what i would have thought :laugh:
ummm... because she is turbo charging an NA??
i'm presuming you dont know much about compresion ratios?? turbo car has a compresion ratio of about 8.5:1, NA is about 14:1, meaning that you cant actually put a massive turbo and/or run much boost on an NA car... its all to do with things exploding =P
Cara, if you haven't done so already, keep in mind the Neo motors have a longer throttle body, so the intake piping to which the BOV is attached to is shorter than your average 33. Therefore the 33 intake piping wil not suit your Neo. Need a Neo DET pipe.
:laugh:
I know its different compression ratios etc......i would really think that it would be worthwhile just getting a DET motor instead of tweaking the NA DE.....and try flogging the DE motor off or use it for spare parts :laugh:
very nice 32 buddy boy^^^.....same BBS wheels as my old bus
you have the coolest job ever Pete
not really Carl.......probably would be if I could charge 1 Gazillion Dollars per year!
LOL Fishy, I think you're thinking of Matty's & my diesel trucks (although they're alot higher than that)....but yeah, comp ratios are higher on NA no doubt.
Guest
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
