also...my missus almost fixed my fuel issue...i showed her where the pump was....she took it out..and diagnosed the problem being the 040 had dropped down in the std cradle causing a lack of fuel getting to the pump....all without braking a nail
Ben are you the luckiest man in the world or what !
well...if it wasnt for her winning a competition on triple m ...my car would still be n/a.....and if it wasnt for her impeccable taste in colours, it'd probably be a crappy blue that would make it look like a daihatsu
LOL Karl, I would've thought it was obvious by now..........same as the fella with the moustache^^^
Well i saw that and said "There's no way SLED does porn"
In truth my uncle used to have a detective business that he started when him and his partner left the police force.
Damo if you were smart you could save 200 bucks a week and by the end of a year have around 10 grand. Then you could go on a nice holiday, buy something nice for your car, etc, etc. Everyone wants everything straight away these days. Saving is pretty damn easy, and it adds up so quickly once you start.
sound words there Karl, i have been doin that for a while, and me and the gf are headed to thailand for a super opulent couple weeks. gonna make it an annual thing :blink:
Ones for the rear leaf spring shackles Luke?
Just been looking through google and that looks like the ones.
FFS, just got a call from my old man saying a car has come around the corner and wiped out our fence at work. Freaken car has driven off and left the fence right down so anyone can walk in.... grrrr
Guest
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
